メインコンテンツにスキップ
Samsung Older French Door Refrigerator - Freezer Icemaker Replacement
必要な工具と部品
  1. Samsung Older French Door Refrigerator - Freezer Icemaker Replacement, Unplug your refrigerator: 手順 1、 1の画像 1
    • Unplug your refrigerator before you begin your repair.
    • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
    • Condenser fan motor
    • Compressor motor and thermal overload device
    • Water supply valve assembly
  2. Samsung Older French Door Refrigerator - Freezer Icemaker Replacement, Freezer Drawer (Older Model): 手順 2、 2の画像 1 Samsung Older French Door Refrigerator - Freezer Icemaker Replacement, Freezer Drawer (Older Model): 手順 2、 2の画像 2
    • Open the freezer drawer.
  3. Samsung Older French Door Refrigerator - Freezer Icemaker Replacement: 手順 3、 3の画像 1 Samsung Older French Door Refrigerator - Freezer Icemaker Replacement: 手順 3、 3の画像 2 Samsung Older French Door Refrigerator - Freezer Icemaker Replacement: 手順 3、 3の画像 3
    • Pull out the upper freezer drawer.
    • Lift the front edge of the drawer.
    • Remove the drawer by lifting it up and out of the freezer compartment.
  4. Samsung Older French Door Refrigerator - Freezer Icemaker Replacement, Remove small drawer basket: 手順 4、 3の画像 1 Samsung Older French Door Refrigerator - Freezer Icemaker Replacement, Remove small drawer basket: 手順 4、 3の画像 2 Samsung Older French Door Refrigerator - Freezer Icemaker Replacement, Remove small drawer basket: 手順 4、 3の画像 3
    • Unclip the basket hinge retainer by tilting the rear edge up and remove it from the drawer rail.
    • Release the small drawer basket and lift it up and out.
  5. Samsung Older French Door Refrigerator - Freezer Icemaker Replacement, Remove the drawer basket: 手順 5、 1の画像 1
    • Lift the drawer basket out of the drawer frame and remove it.
  6. Samsung Older French Door Refrigerator - Freezer Icemaker Replacement, Unfasten the drawer front: 手順 6、 2の画像 1 Samsung Older French Door Refrigerator - Freezer Icemaker Replacement, Unfasten the drawer front: 手順 6、 2の画像 2
    • Use a 3/8" socket wrench, box wrench, or open end wrench to remove the bolts securing the drawer front to the right drawer slide.
    • Repeat the process for the left drawer slide.
  7. Samsung Older French Door Refrigerator - Freezer Icemaker Replacement, Remove the drawer front: 手順 7、 3の画像 1 Samsung Older French Door Refrigerator - Freezer Icemaker Replacement, Remove the drawer front: 手順 7、 3の画像 2 Samsung Older French Door Refrigerator - Freezer Icemaker Replacement, Remove the drawer front: 手順 7、 3の画像 3
    • Lift the drawer front upwards to free it from the drawer slides.
    • Remove the drawer front.
  8. Samsung Older French Door Refrigerator - Freezer Icemaker Replacement, Release the connector rod retaining pin: 手順 8、 3の画像 1 Samsung Older French Door Refrigerator - Freezer Icemaker Replacement, Release the connector rod retaining pin: 手順 8、 3の画像 2 Samsung Older French Door Refrigerator - Freezer Icemaker Replacement, Release the connector rod retaining pin: 手順 8、 3の画像 3
    • Rotate the slide connector rod until you can access the retaining pin.
    • Use a pair of long nose pliers to squeeze the retaining pin shank to release it.
  9. Samsung Older French Door Refrigerator - Freezer Icemaker Replacement, Remove the drawer slide connecting rod: 手順 9、 2の画像 1 Samsung Older French Door Refrigerator - Freezer Icemaker Replacement, Remove the drawer slide connecting rod: 手順 9、 2の画像 2
    • Pull the retaining pin out of the hole.
    • Slide the connecting rod to the right to free the left end of the rod.
    • Remove the rod by lifting it upward and sliding it back to the left.
  10. Samsung Older French Door Refrigerator - Freezer Icemaker Replacement, Unfasten the freezer icemaker: 手順 10、 2の画像 1 Samsung Older French Door Refrigerator - Freezer Icemaker Replacement, Unfasten the freezer icemaker: 手順 10、 2の画像 2
    • Use a #2 Phillips driver to remove the retaining screws.
    • Two views of the same screws are shown for clarity. There are not four screws.
  11. Samsung Older French Door Refrigerator - Freezer Icemaker Replacement, Reposition the icemaker: 手順 11、 2の画像 1 Samsung Older French Door Refrigerator - Freezer Icemaker Replacement, Reposition the icemaker: 手順 11、 2の画像 2
    • Pull the icemaker forward parallel to the top of the freezer.
    • This will release the icemaker from the freezer top.
    • Reposition the icemaker and hold it in one hand to prepare to disconnect it.
  12. Samsung Older French Door Refrigerator - Freezer Icemaker Replacement, Disconnect the icemaker: 手順 12、 3の画像 1 Samsung Older French Door Refrigerator - Freezer Icemaker Replacement, Disconnect the icemaker: 手順 12、 3の画像 2 Samsung Older French Door Refrigerator - Freezer Icemaker Replacement, Disconnect the icemaker: 手順 12、 3の画像 3
    • Grasp the icemaker connector (the one to the front) and squeeze the release tab.
    • Pull the connector out from the socket.
  13. Samsung Older French Door Refrigerator - Freezer Icemaker Replacement, Remove the icemaker: 手順 13、 2の画像 1 Samsung Older French Door Refrigerator - Freezer Icemaker Replacement, Remove the icemaker: 手順 13、 2の画像 2
    • Remove the ice maker.
    • This view shows the slots that the mounting studs on the freezer top for reference when reassembling.
終わりに
Repair didn’t go as planned? Ask our Answers Community for help.
作成者
1人の作成者と共同作成されました。
Bill Gilbert
メンバー登録日: 06/30/22
37,455 ポイント
261のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
118 メンバー
19,623のガイドは作成済み
0 Guide Comments
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 18
過去 30 日: 28
今までの合計 60
