はじめに
The motherboard of the Fit is hidden deep insde the device, but once it's revealed, removal is just a matter of disconnecting a few ribbon cables.
必要なもの
Place your thumbs on the ends of the screen.
Push the watch outward while pulling the band away from the watch.
Use a hair dryer, heat gun, or an iOpener to heat the Gear Fit for 1-2 minutes until it is hot to the touch.
Three ribbon cables hold the motherboard to the rest of the assembly.
The battery cable in the front.
And two on the side.
Using a pair of tweezers, carefully pull each connector away to disconnect it from the rest of the assembly.
2 の人々がこのガイドを完成させました。
