メインコンテンツにスキップ
Samsung Galaxy Watch Active2 Screen Replacement
必要な工具と部品
  1. Samsung Galaxy Watch Active2 Screen Replacement, Turn off the watch: 手順 1、 2の画像 1 Samsung Galaxy Watch Active2 Screen Replacement, Turn off the watch: 手順 1、 2の画像 2
    • Turn off the Galaxy Watch Active2 by pushing and holding the bottom button for approximately 3 seconds. You should feel a short vibration.
    • When the "Power off" symbol appears, tap the center of the screen to make it shut down. You should feel a longer vibration for confirmation.
  2. Samsung Galaxy Watch Active2 Screen Replacement, Remove the rear screws: 手順 2、 1の画像 1
    • Use a Tri-point Y00 screwdriver to remove the four 4 mm-long screws on the back of the watch.
  3. Samsung Galaxy Watch Active2 Screen Replacement, Separate the back cover from the housing: 手順 3、 3の画像 1 Samsung Galaxy Watch Active2 Screen Replacement, Separate the back cover from the housing: 手順 3、 3の画像 2 Samsung Galaxy Watch Active2 Screen Replacement, Separate the back cover from the housing: 手順 3、 3の画像 3
    • Use an opening pick and place it between the plastic back cover and the metal housing near the buttons.
    • Push the opening pick into the gap to separate the back cover from the housing.
    • Don’t remove the back cover all the way yet. There is a cable connecting it to the motherboard.
  4. Samsung Galaxy Watch Active2 Screen Replacement, Disconnect the sensor array: 手順 4、 2の画像 1 Samsung Galaxy Watch Active2 Screen Replacement, Disconnect the sensor array: 手順 4、 2の画像 2
    • Carefully lift the back cover to access the sensor array connector.
    • Use a spudger to disconnect the sensor array from the motherboard.
  5. Samsung Galaxy Watch Active2 Screen Replacement, Remove the back cover: 手順 5、 1の画像 1
    • Remove the back cover.
  6. Samsung Galaxy Watch Active2 Screen Replacement, Disconnect the display and speaker: 手順 6、 3の画像 1 Samsung Galaxy Watch Active2 Screen Replacement, Disconnect the display and speaker: 手順 6、 3の画像 2 Samsung Galaxy Watch Active2 Screen Replacement, Disconnect the display and speaker: 手順 6、 3の画像 3
    • Use a spudger to disconnect the display assembly and the speaker.
  7. Samsung Galaxy Watch Active2 Screen Replacement, Disconnect the barometric sensor, buttons, and mic: 手順 7、 3の画像 1 Samsung Galaxy Watch Active2 Screen Replacement, Disconnect the barometric sensor, buttons, and mic: 手順 7、 3の画像 2 Samsung Galaxy Watch Active2 Screen Replacement, Disconnect the barometric sensor, buttons, and mic: 手順 7、 3の画像 3
    • Use a spudger to disconnect the barometric sensor, the buttons, and the microphone.
  8. Samsung Galaxy Watch Active2 Screen Replacement, Lift the core assembly: 手順 8、 2の画像 1 Samsung Galaxy Watch Active2 Screen Replacement, Lift the core assembly: 手順 8、 2の画像 2
    • Place a spudger underneath the motherboard at the top right next to the display connector.
    • Slightly twist and lever the spudger to loosen the core assembly.
    • It might help to also check the comments below this and the next step if you’re having difficulties.
  9. Samsung Galaxy Watch Active2 Screen Replacement, Remove the core assembly: 手順 9、 3の画像 1 Samsung Galaxy Watch Active2 Screen Replacement, Remove the core assembly: 手順 9、 3の画像 2 Samsung Galaxy Watch Active2 Screen Replacement, Remove the core assembly: 手順 9、 3の画像 3
    • Grab the core assembly and carefully slide it out from under the cables.
    • Remove the core assembly.
  10. Samsung Galaxy Watch Active2 Screen Replacement, Loosen the display: 手順 10、 3の画像 1 Samsung Galaxy Watch Active2 Screen Replacement, Loosen the display: 手順 10、 3の画像 2 Samsung Galaxy Watch Active2 Screen Replacement, Loosen the display: 手順 10、 3の画像 3
    • Place the edge of an opening tool under the speaker unit.
    • Lever the opening tool down to separate the display from the frame.
  11. Samsung Galaxy Watch Active2 Screen Replacement, Remove the frame: 手順 11、 2の画像 1 Samsung Galaxy Watch Active2 Screen Replacement, Remove the frame: 手順 11、 2の画像 2
    • Remove the frame from the display.
    • Make sure to remove any remaining adhesive from the frame with isopropyl alcohol (>90%) before applying the adhesive or installing the new display.
終わりに
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%). You may need to remove adhesive backings from the new part before installing.
29 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Tobias Isakeit
メンバー登録日: 03/31/14
124,137 ポイント
189のガイドは作成済み
チーム
Tobias Isakeit - Repairability Engineer Tobias Isakeit - Repairability Engineer人のメンバー
Business
1 メンバー
1,131のガイドは作成済み
17 件のコメント
Does anyone know where to buy the replacement screen for Active 2? Or what keywords should I search for (SKU or model)?
Angelo Sembrano - 返信
SM-R830 for the 40mm version, SM-R820 for the 44mm one. People on ebay resell them but they cost upwards of $100. I’d look into broken watches of the same type that maybe the battery is dead and they’re selling it for cheap, then do a swap job on the (hopefully) working screen.
Justin Collins -
Seconding the question on where to buy a replacement screen
Arjun Ramakrishnan - 返信
You could be lucky on rounded.com
Tobias Isakeit - 返信
What adhesive would be best to use?
Kelsey Crank - 返信
コメントを追加
統計データ:
過去 24時間: 28
過去 7 日: 186
過去 30 日: 853
今までの合計 95,040
