はじめに
This guide will help you replace the front facing camera in your device. You’re going to need to open up the device first with a heating mechanism, and you’re going to need a couple of other tools to complete this guide.
必要な工具と部品
To soften the adhesive holding the tablet together, heat up the edges of the glass panel using a heated iOpener on the edge of the device. Alternatively you can use a heat gun to loosen the adhesive.
Leave the iOpener on edge for two minutes.
この手順で使用する道具:Plastic Cards$2.99
As you continue along the edge using the opening tool, use a plastic card to keep the glass separate from the midframe.
Repeat steps 3 through 7 to remove the rear glass panel on the opposite side of the device.
Use a Phillips #000 screwdriver to unscrew the five screws securing the battery, and the twenty-two screws surrounding the midframe.
ある他の人がこのガイドを完成しました。
