はじめに
It is normal for lithium-ion batteries, such as the one found in the Galaxy Tab S3, to sustain damage after each charge cycle and eventually degrade over time. Most tablet batteries are designed to last about 2 to 3 years before becoming too worn out for normal use. If your battery is worn out and no longer holds a charge, you might want to consider replacing it. This guide will show you how to properly remove and replace the battery.
必要な工具と部品
To soften the adhesive holding the tablet together, heat up the edges of the glass panel using a heated iOpener on the edge of the device. Alternatively you can use a heat gun to loosen the adhesive.
Leave the iOpener on edge for two minutes.
Place a suction cup near edge that you heated up with the iOpener.
Press down on the suction cup to create a seal, and pull up with force to create a separation between the display and the midframe.
Use an opening tool to split apart the glass panel from the midframe.
Bonjour, pour moi il est IMPÉRATIF d’opérer l’ouverture par le bord droit comme indiqué sur le tuto car de l’autre coté les nappes du LCD ne sont qu’à 3mm du bord et peuvent etre abimée comme je l’ai fait lors du décollage.
この手順で使用する道具:Plastic Cards$2.99
As you continue along the edge using the opening tool, use a plastic card to keep the glass separate from the midframe.
For this part I recommend to insert the tools only on top, bottom and right side. Then lift the screen as shown in the pictures in step 4. The left side has the light ribbons for the display too close to the edge and they are really thin. I just broke the four of them in my screen :(
Repeat steps 3 through 7 to remove the rear glass panel on the opposite side of the device.
Use a Phillips #000 screwdriver to unscrew the five screws securing the battery, and the twenty-two screws surrounding the midframe.
To reassemble your device, follow these instructions in reverse order. If you have removed too much adhesive, you may need to apply more during the reassembly process.
9 の人々がこのガイドを完成させました。
7 件のコメント
This repair can be done without removing the screen!
how? would it be simpler to do it that way?
There is no reason to remove the screen. It’s super risky to do it that way. When you take the battery out, just use some alcohol on the sides of the battery to weaken the adhesive and use a suction cup to pull the battery out. No need to push on it from the screen side.
What I get for reading a guide before checking comment, TOTALLY unnecessary step in removing screen. LCD cost $220 on ebay….
Un vrai tuto de merde avec lequel vous êtes assuré de niquer votre tablette !!! Je vous recommande expressément de rechercher sur youtube “ How to Replace Your Samsung Galaxy Tab S3 SM-T825 Battery “ pour trouver un VRAI TUTO simple et qui vous évitera à coup sur de flinguer votre écran.
P de Rochefort
How many times are you guys heating up the tablet to get it to loose
Do not remove the screen. Take the back off of the tablet and remove the battery. The screen will crack extremely easily.
There is no reason to remove the screen while replacing a battery.
Nick Youngstrom - 返信
Agreed , just remove back and warm up. Dont remove screen, is $220 to replace off ebay.
Phenix City - 返信
