メインコンテンツにスキップ
Samsung Galaxy Tab S3 Battery Replacement
必要な工具と部品
  1. Samsung Galaxy Tab S3  Battery Replacement, Display: 手順 1、 1の画像 1
    • To soften the adhesive holding the tablet together, heat up the edges of the glass panel using a heated iOpener on the edge of the device. Alternatively you can use a heat gun to loosen the adhesive.
    • Leave the iOpener on edge for two minutes.
    • Be careful not to burn yourself while handling the hot iOpener. For more information on the iOpener, use the iOpener Instructions Guide.
    There is no reason to remove the screen while replacing a battery.
    Nick Youngstrom - 返信
    Agreed , just remove back and warm up. Dont remove screen, is $220 to replace off ebay.
    Phenix City - 返信
  2. Samsung Galaxy Tab S3  Battery Replacement: 手順 2、 1の画像 1
    • Place a suction cup near edge that you heated up with the iOpener.
    • Press down on the suction cup to create a seal, and pull up with force to create a separation between the display and the midframe.
    • Use an opening tool to split apart the glass panel from the midframe.
    • Be careful to not break the glass when prying from the frame.
    Bonjour, pour moi il est IMPÉRATIF d’opérer l’ouverture par le bord droit comme indiqué sur le tuto car de l’autre coté les nappes du LCD ne sont qu’à 3mm du bord et peuvent etre abimée comme je l’ai fait lors du décollage.
    Jacques Barreau - 返信
  3. Samsung Galaxy Tab S3  Battery Replacement: 手順 3、 1の画像 1
    この手順で使用する道具:
    Plastic Cards
    $2.99
    購入する
    • As you continue along the edge using the opening tool, use a plastic card to keep the glass separate from the midframe.
    • You can also use multiple opening picks instead of a plastic card.
    For this part I recommend to insert the tools only on top, bottom and right side. Then lift the screen as shown in the pictures in step 4. The left side has the light ribbons for the display too close to the edge and they are really thin. I just broke the four of them in my screen :(
    Moisés Jover - 返信
  4. Samsung Galaxy Tab S3  Battery Replacement: 手順 4、 3の画像 1 Samsung Galaxy Tab S3  Battery Replacement: 手順 4、 3の画像 2 Samsung Galaxy Tab S3  Battery Replacement: 手順 4、 3の画像 3
    • Pull off the glass panel using the suction cup.
    • As you remove the glass panel, be careful not to tear the ribbon connecting the motherboard to the display.
    • Carefully disconnect the ribbon cable connecting the display assembly to the motherboard. You can disconnect this ribbon from either end.
  5. Samsung Galaxy Tab S3  Battery Replacement, Rear glass panel: 手順 5、 2の画像 1 Samsung Galaxy Tab S3  Battery Replacement, Rear glass panel: 手順 5、 2の画像 2
    • Repeat steps 3 through 7 to remove the rear glass panel on the opposite side of the device.
  6. Samsung Galaxy Tab S3  Battery Replacement, Battery: 手順 6、 2の画像 1 Samsung Galaxy Tab S3  Battery Replacement, Battery: 手順 6、 2の画像 2
    • Use a Phillips #000 screwdriver to unscrew the five screws securing the battery, and the twenty-two screws surrounding the midframe.
  7. Samsung Galaxy Tab S3  Battery Replacement: 手順 7、 1の画像 1
    • The midframe should snap off from the device’s motherboard.
  8. Samsung Galaxy Tab S3  Battery Replacement: 手順 8、 3の画像 1 Samsung Galaxy Tab S3  Battery Replacement: 手順 8、 3の画像 2 Samsung Galaxy Tab S3  Battery Replacement: 手順 8、 3の画像 3
    • Locate the ribbon running from the midframe and disconnect it from the motherboard with the flat end of a spudger.
  9. Samsung Galaxy Tab S3  Battery Replacement: 手順 9、 2の画像 1 Samsung Galaxy Tab S3  Battery Replacement: 手順 9、 2の画像 2
    • Use the flat end of the spudger to pop off the connector between the battery and the motherboard.
  10. Samsung Galaxy Tab S3  Battery Replacement: 手順 10、 2の画像 1 Samsung Galaxy Tab S3  Battery Replacement: 手順 10、 2の画像 2
    • Flip the midframe over and pop the battery out, making sure to slide it out from underneath the ribbon cables.
  11. Samsung Galaxy Tab S3  Battery Replacement: 手順 11、 1の画像 1
    • The battery should now be removed and detached from the device.
終わりに
To reassemble your device, follow these instructions in reverse order. If you have removed too much adhesive, you may need to apply more during the reassembly process.
9 の人々がこのガイドを完成させました。
作成者
10人の作成者と共同で作成されました。
Mimi Fucini
メンバー登録日: 04/18/18
684 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team S22-G4, Maness Spring 2018 Cal Poly, Team S22-G4, Maness Spring 2018人のメンバー
CPSU-MANESS-S18S22G4
5 メンバー
15のガイドは作成済み
7 件のコメント
This repair can be done without removing the screen!
hansderaedt - 返信
how? would it be simpler to do it that way?
Ryan McDaniel -
There is no reason to remove the screen. It’s super risky to do it that way. When you take the battery out, just use some alcohol on the sides of the battery to weaken the adhesive and use a suction cup to pull the battery out. No need to push on it from the screen side.
What I get for reading a guide before checking comment, TOTALLY unnecessary step in removing screen. LCD cost $220 on ebay….
Phenix City - 返信
Un vrai tuto de merde avec lequel vous êtes assuré de niquer votre tablette !!! Je vous recommande expressément de rechercher sur youtube “ How to Replace Your Samsung Galaxy Tab S3 SM-T825 Battery “ pour trouver un VRAI TUTO simple et qui vous évitera à coup sur de flinguer votre écran.
P de Rochefort
psurbook - 返信
How many times are you guys heating up the tablet to get it to loose
henry prophete - 返信
Do not remove the screen. Take the back off of the tablet and remove the battery. The screen will crack extremely easily.
Matt Barber - 返信
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 35
過去 30 日: 231
今までの合計 23,751
