はじめに
Broken speakers prevent your tablet from producing quality sound or any sound at all. Removing the speakers may require an iOpener or a heat gun. Check out this iOpener guide for instructions on how to use it.
必要な工具と部品
Using the Philips #000 screwdriver, remove the seventeen 2.74 mm screws around the edges.
Remove the two 2.74 mm black screws in the middle of the tablet with the Philips #000 screwdriver.
Locate the speakers towards the bottom.
For the speaker on the left, use the plastic opening tool to lift up the press-fit connector.
3 の人々がこのガイドを完成させました。
