はじめに
A broken camera can cause poor photo quality or may not be able to take any photos at all.
必要な工具と部品
Using the Philips #000 screwdriver, remove the seventeen 2.74 mm screws around the edges.
Remove the two 2.74 mm black screws in the middle of the tablet with the Philips #000 screwdriver.
Locate the two cameras at the top of the motherboard.
To remove the bigger, back-facing camera, use the precision tweezers to slide the silver ribbon cable out of the ZIF connector.
ある他の人がこのガイドを完成しました。
