メインコンテンツにスキップ
Samsung Galaxy Tab S2 9.7 AT&T Battery Replacement
必要な工具と部品
  1. Samsung Galaxy Tab S2 9.7 AT&T Battery Replacement, Screen: 手順 1、 2の画像 1 Samsung Galaxy Tab S2 9.7 AT&T Battery Replacement, Screen: 手順 1、 2の画像 2
    • Apply the heat gun around the edges of the tablet to melt the adhesive glue.
    • Do not allow the gun to remain still for more than two seconds, so that you do not melt the plastic around the screen.
    • If you do not have access to a heat gun, you may also use an iOpener or a hair dryer. Refer to the iOpener guide for extra help.
  2. Samsung Galaxy Tab S2 9.7 AT&T Battery Replacement: 手順 2、 2の画像 1 Samsung Galaxy Tab S2 9.7 AT&T Battery Replacement: 手順 2、 2の画像 2
    • Apply the suction to the bottom or top right corner.
    • Use the plastic opening tool at several points around the screen while the suction is being applied to pop the screen out.
  3. Samsung Galaxy Tab S2 9.7 AT&T Battery Replacement: 手順 3、 1の画像 1
    • Once the screen is detached, open the tablet like a book.
    • Gently open the tablet, and do not pull the pieces apart since you can risk damaging the orange ribbon cable.
  4. Samsung Galaxy Tab S2 9.7 AT&T Battery Replacement: 手順 4、 1の画像 1
    この手順で使用する道具:
    購入する
    • Using the precision tweezers, remove the silver tape that is holding the orange ribbon cable connecting the two pieces.
  5. Samsung Galaxy Tab S2 9.7 AT&T Battery Replacement: 手順 5、 1の画像 1
    • Using the precision tweezers, remove the small press-fit connector from the body of the tablet.
  6. Samsung Galaxy Tab S2 9.7 AT&T Battery Replacement, Screws: 手順 6、 2の画像 1 Samsung Galaxy Tab S2 9.7 AT&T Battery Replacement, Screws: 手順 6、 2の画像 2
    • Using the Philips #000 screwdriver, remove the seventeen 2.74 mm screws around the edges.
    • Remove the two 2.74 mm black screws in the middle of the tablet with the Philips #000 screwdriver.
    • Put the screws on a magnetic project mat or in a container so that you do not lose them.
  7. Samsung Galaxy Tab S2 9.7 AT&T Battery Replacement: 手順 7、 3の画像 1 Samsung Galaxy Tab S2 9.7 AT&T Battery Replacement: 手順 7、 3の画像 2 Samsung Galaxy Tab S2 9.7 AT&T Battery Replacement: 手順 7、 3の画像 3
    • Take the plastic opening tool around the tablet to remove the motherboard from the device.
  8. Samsung Galaxy Tab S2 9.7 AT&T Battery Replacement, Battery: 手順 8、 2の画像 1 Samsung Galaxy Tab S2 9.7 AT&T Battery Replacement, Battery: 手順 8、 2の画像 2
    • At the bottom left of the battery, use the plastic opening tool to detach the lower press-fit connector of the black ribbon cable.
    • Using the plastic opening tool, detach the press-fit connector on the left side of the black ribbon cable.
    • Lift up the black ribbon cable to remove it.
  9. Samsung Galaxy Tab S2 9.7 AT&T Battery Replacement: 手順 9、 1の画像 1
    • Using the plastic opening tool, detach the orange ribbon cable connecting the battery to the motherboard.
  10. Samsung Galaxy Tab S2 9.7 AT&T Battery Replacement: 手順 10、 2の画像 1 Samsung Galaxy Tab S2 9.7 AT&T Battery Replacement: 手順 10、 2の画像 2
    • Using the Phillips #000 Screwdriver, remove the four 2.74mm black screws around the edge of the battery.
  11. Samsung Galaxy Tab S2 9.7 AT&T Battery Replacement: 手順 11、 1の画像 1
    • The battery is now fully detached from the motherboard.
    • Lift up the battery to remove it from the motherboard.
終わりに
3 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Joy Harris
メンバー登録日: 02/15/17
814 ポイント
7のガイドは作成済み
チーム
USF Tampa, Team S3-G4, Sullivan Spring 2017 USF Tampa, Team S3-G4, Sullivan Spring 2017人のメンバー
USFT-SULLIVAN-S17S3G4
3 メンバー
14のガイドは作成済み
4 件のコメント
impossible de décoller l’écran de la tablette
vatin1998 - 返信
Le tuto est parfaitement clair et précis. Un grand Merci.
Néanmoins il faut reconnaître que cette opération n’est pas simple du tout et qu’elle n’est pas sans risque, même en étant très méticuleux.
Pour ouvrir la coque, il faut obligatoirement un minimum de matériel adapté et malgré cela, c’est une galère !
Christian Muller - 返信
Pour info sur la Galaxy tab s2 votre tuto est faux. Merci j'ai cassé le haut de mon écran. Grace à un autre site jai pu voir qu'il faut enlever le capot arrière pour accéder à la batterie
Sébastien Colonges - 返信
Bonjour, pourquoi passer par la face avant très fragile alors que le démontage de la face arrière est beaucoup plus aisée et donne accès à la batterie comme à l'étape 8. A revoir ou à expliquer.
JPG93500 - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 11
過去 30 日: 60
今までの合計 20,973
