メインコンテンツにスキップ
Samsung Galaxy Tab E 9.6, Verizon Home Button Replacement
必要な工具と部品
  1. Samsung Galaxy Tab E 9.6, Verizon Home Button Replacement, Back Casing: 手順 1、 1の画像 1
    • Remove any micro-SD or SIM cards before continuing.
    • Verify your device is turned OFF.
    • Disconnect all external devices from your tablet.
  2. Samsung Galaxy Tab E 9.6, Verizon Home Button Replacement: 手順 2、 3の画像 1 Samsung Galaxy Tab E 9.6, Verizon Home Button Replacement: 手順 2、 3の画像 2 Samsung Galaxy Tab E 9.6, Verizon Home Button Replacement: 手順 2、 3の画像 3
    • Insert the plastic opening tool by wedging it between the device's screen and back cover.
    • Move the plastic tool around the edges of the device to undo the plastic lips holding the casing together.
    • This step may require more force than expected. If difficult, try using a suction cup on the screen.
  3. Samsung Galaxy Tab E 9.6, Verizon Home Button Replacement: 手順 3、 3の画像 1 Samsung Galaxy Tab E 9.6, Verizon Home Button Replacement: 手順 3、 3の画像 2 Samsung Galaxy Tab E 9.6, Verizon Home Button Replacement: 手順 3、 3の画像 3
    • This process will become easier as more clips are separated.
    • Use your hands to gently pull the back cover off the device after about half of the clips are separated.
    • A suction cup can be used in this step as well to assist in pulling the device apart.
  4. Samsung Galaxy Tab E 9.6, Verizon Home Button Replacement, Front Panel: 手順 4、 2の画像 1 Samsung Galaxy Tab E 9.6, Verizon Home Button Replacement, Front Panel: 手順 4、 2の画像 2
    この手順で使用する道具:
    購入する
    • Turn the device over so the screen is facing down. Locate the front panel assembly connector at the top left corner of the motherboard.
    • To remove the connector, first use a pair of tweezers and flip the connector lock upwards towards the battery.
  5. Samsung Galaxy Tab E 9.6, Verizon Home Button Replacement: 手順 5、 1の画像 1
    • Once you've undone the connector lock, use a pair of tweezers to pull the cable front its housing.
  6. Samsung Galaxy Tab E 9.6, Verizon Home Button Replacement: 手順 6、 1の画像 1
    • Turn the device back over and use a plastic opening tool to detach the adhesive glue securing the front casing.
    • You will need to wedge a plastic opening tool in between the front casing and the screen. Then move the tool around the perimeter of the device to break the adhesive.
    • Once you've loosed the front panel enough with the prying tool, you can use your hands to pull the front panel off of the device.
  7. Samsung Galaxy Tab E 9.6, Verizon Home Button Replacement, Home Button: 手順 7、 1の画像 1
    • Unlock the ZIF connector to release ribbon cable that lays across the battery.
  8. Samsung Galaxy Tab E 9.6, Verizon Home Button Replacement: 手順 8、 1の画像 1
    この手順で使用する道具:
    購入する
    • Gray padding covers the ribbon wires connected to the home button. Before removing the wires, gently remove the padding with tweezers.
  9. Samsung Galaxy Tab E 9.6, Verizon Home Button Replacement: 手順 9、 3の画像 1 Samsung Galaxy Tab E 9.6, Verizon Home Button Replacement: 手順 9、 3の画像 2 Samsung Galaxy Tab E 9.6, Verizon Home Button Replacement: 手順 9、 3の画像 3
    • To remove the home button for replacement, locate a strip of ribbon wire on the back of the tablet at the bottom.
    • Using the tweezers, slowly pull the ribbon wire, being careful to not rip the wire or damage any surrounding parts.
    • Underneath the home button, you will find more ribbon wire. Do not remove this ribbon wire until the home button has been removed.
  10. Samsung Galaxy Tab E 9.6, Verizon Home Button Replacement: 手順 10、 2の画像 1 Samsung Galaxy Tab E 9.6, Verizon Home Button Replacement: 手順 10、 2の画像 2
    • Once the ribbon wire has been disconnected from the back, flip the tablet over to remove the home button.
    • Using tweezers, securely grab the home button and pull until it has been removed. You should now be able to see the remainder of the ribbon wire.
    • If the ribbon wire is the reason for the faulty home button, remove the remainder of it and replace it with a new ribbon wire.
終わりに
To reassemble your device, reverse the steps in the instructions.
ある他の人がこのガイドを完成しました。
作成者
5人の作成者と共同で作成されました。
William Gorham Jr
メンバー登録日: 09/28/16
57 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team 1-4, Cagle Fall 2016 USF Tampa, Team 1-4, Cagle Fall 2016人のメンバー
USFT-CAGLE-F16S1G4
3 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 16
今までの合計 1,353
