はじめに
If there is no sound coming from your speakers, this guide will instruct you on how to replace the speakers.
必要な工具と部品
Have the front of the device facing you.
Begin near one of the curved edges of the device (see photo two for visual example).
Place a plastic opening tool between the front and back panels.
Remove the adhesive film and flip up the retaining flap on the ZIF battery connector.
Slide the orange battery ribbon cable out of the ZIF connector.
Using a Phillips #000 screwdriver, remove the ten 4 mm screws around the battery.
Slide a plastic opening tool under the bottom of the battery close to the speakers and lift up.
2 の人々がこのガイドを完成させました。
2 件のコメント
Where is a good place to buy the replacement speaker?
Where is a good place to buy a speaker?
