メインコンテンツにスキップ
Samsung Galaxy Tab A 10.1 Speaker Replacement
必要な工具と部品
  1. Samsung Galaxy Tab A 10.1 Speaker Replacement, Back Panel: 手順 1、 2の画像 1 Samsung Galaxy Tab A 10.1 Speaker Replacement, Back Panel: 手順 1、 2の画像 2
    • Have the front of the device facing you.
    • Begin near one of the curved edges of the device (see photo two for visual example).
    • Place a plastic opening tool between the front and back panels.
    • If a plastic opening tool doesn’t work, using a metal spudger may work, but it may damage the plastic on the device.
    • Remember to remove the micro SD card (if present) before you begin.
  2. Samsung Galaxy Tab A 10.1 Speaker Replacement: 手順 2、 2の画像 1 Samsung Galaxy Tab A 10.1 Speaker Replacement: 手順 2、 2の画像 2
    • Once the plastic opening tool is fully inserted, wedge it around the device’s edges to separate the panels.
    • Lift the back panel off of the device.
    • The back panel will make a clicking noise while being lifted off of the device.
  3. Samsung Galaxy Tab A 10.1 Speaker Replacement, Disconnecting the battery: 手順 3、 1の画像 1
    • Remove the adhesive film and flip up the retaining flap on the ZIF battery connector.
    • Slide the orange battery ribbon cable out of the ZIF connector.
  4. Samsung Galaxy Tab A 10.1 Speaker Replacement: 手順 4、 2の画像 1 Samsung Galaxy Tab A 10.1 Speaker Replacement: 手順 4、 2の画像 2
    • Remove the adhesive film, lift the retaining tab and withdraw the white speaker ribbon.
  5. Samsung Galaxy Tab A 10.1 Speaker Replacement: 手順 5、 3の画像 1 Samsung Galaxy Tab A 10.1 Speaker Replacement: 手順 5、 3の画像 2 Samsung Galaxy Tab A 10.1 Speaker Replacement: 手順 5、 3の画像 3
    • Lift the retaining tab and withdraw the black LCD ribbon.
  6. Samsung Galaxy Tab A 10.1 Speaker Replacement, Battery removal: 手順 6、 2の画像 1 Samsung Galaxy Tab A 10.1 Speaker Replacement, Battery removal: 手順 6、 2の画像 2
    • Using a Phillips #000 screwdriver, remove the ten 4 mm screws around the battery.
    • Slide a plastic opening tool under the bottom of the battery close to the speakers and lift up.
    • The large rectangular white and black piece is the entire battery. Be careful not to puncture it.
  7. Samsung Galaxy Tab A 10.1 Speaker Replacement, Speaker: 手順 7、 1の画像 1
    • Use Phillips # 000 to remove the 4 mm .3 cm screw on each speaker.
    • If you encounter a stripped screw, see iFixit’s guide on how to remove it here.
  8. Samsung Galaxy Tab A 10.1 Speaker Replacement: 手順 8、 1の画像 1
    • Place the plastic opening tool on the edge of the speaker.
    • Lodge the plastic opening tool under each speaker and lift them up and out of the device.
終わりに
2 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Isabella Li
メンバー登録日: 10/02/17
2,376 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team S15-G6, Livingston Fall 2017 Cal Poly, Team S15-G6, Livingston Fall 2017人のメンバー
CPSU-LIVINGSTON-F17S15G6
4 メンバー
26のガイドは作成済み
2 件のコメント
Where is a good place to buy the replacement speaker?
Max Alberts - 返信
Where is a good place to buy a speaker?
Max Alberts - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 44
今までの合計 4,222
