メインコンテンツにスキップ
Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement
必要な工具と部品
  1. Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement, Battery: 手順 1、 2の画像 1 Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement, Battery: 手順 1、 2の画像 2
    • Remove all external power and turn off the tablet.
    • Insert a plastic opening tool between the screen and rear casing.
    • Pry the screen and rear casing apart.
  2. Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement: 手順 2、 3の画像 1 Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement: 手順 2、 3の画像 2 Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement: 手順 2、 3の画像 3
    • Remove the three green pieces of tape covering the white, black, and gold ribbon cables.
    • Use a spudger to flip up the retaining flap on the three ribbon cable ZIF sockets.
    • Pull the ribbon cables out of the sockets.
  3. Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement: 手順 3、 3の画像 1 Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement: 手順 3、 3の画像 2 Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement: 手順 3、 3の画像 3
    • Remove the ten 4mm Phillips #000 screws from the battery.
    • Use a plastic opening tool to pry up the battery.
    • Remove the battery.
  4. Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement, Screen: 手順 4、 3の画像 1 Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement, Screen: 手順 4、 3の画像 2 Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement, Screen: 手順 4、 3の画像 3
    • Remove the six 4mm Phillips #000 screws from the motherboard.
    • Use a spudger to flip up the retaining flap on the ribbon cable ZIF sockets.
    • Use the plastic opening tool to remove the motherboard from the case.
  5. Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement: 手順 5、 2の画像 1 Samsung Galaxy Tab A 10.1 S-Pen Screen Replacement: 手順 5、 2の画像 2
    • Insert a plastic opening tool between the screen and bezel.
    • Slide the plastic opening tool around the perimeter while prying upwards until the screen separates from the bezel.
    • The screen may crack during this process so be wary of broken glass.
    • Applying heat may be necessary to loosen the glue.
終わりに
4 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Guneet Bawa
メンバー登録日: 04/12/18
679 ポイント
4のガイドは作成済み
チーム
UW Tacoma, Team S1-G5, Liner Spring 2018 UW Tacoma, Team S1-G5, Liner Spring 2018人のメンバー
UWT-LINER-S18S1G5
5 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 28
今までの合計 3,297
