メインコンテンツにスキップ
Samsung Galaxy Tab 2 10.1 Front Camera Replacement
必要な工具と部品
  1. Samsung Galaxy Tab 2 10.1 Front Camera Replacement, Back Cover: 手順 1、 2の画像 1 Samsung Galaxy Tab 2 10.1 Front Camera Replacement, Back Cover: 手順 1、 2の画像 2
    この手順で使用する道具:
    Heavy-Duty Spudger
    • The plastic opening tool may break during this step. You may need to use the heavy duty spudger instead.
    • Insert the plastic opening tool between the glass screen and the back cover so the curved end of the plastic opening tool is under the glass. Gently pry the back cover away from the glass screen.
    • Be sure to lift the entire display from the body and that you are not are lifting the glass from the display. You will need to reach down a little further for the correct removal.
    • Continue inserting the plastic opening tool around the whole device screen to completely separate the back cover from the glass screen.
    Note that the headphone port protrudes into the back cover framing. Hence the rest of the back needs to be unclipped and taken off first.
    Levi Howard - 返信
    I had problems getting it to separate at first. Pushing down with my thumb on the very edge of the case from the front while pushing up with my fingers from the back flexed it enough to get a very small jeweler’s screwdriver in the gap. From there I worked it until I could get the little bread wrapper plastics clips in the space. When it needed something stronger a 1 or 2 inch plastic putty knife from Walmart did the trick.
    William H Bowers - 返信
    I replaced the battery and nothing no screen nothing. the batt was 3.7 V though.
    The old one had 0V. I might have messed up the ribbon cables?
    I put back the cover on it.
    Held on the power button for 10 seconds, nothing. Held the power button and the volume up button for 10 seconds… also nothing..
    I am leaving it charge for a while now. Even though if your battery is like full (3.7V measured) it should come on… but nothing..
    Lets wait and see. Or this will be garbage…
    xbox40489 - 返信
  2. Samsung Galaxy Tab 2 10.1 Front Camera Replacement: 手順 2、 2の画像 1 Samsung Galaxy Tab 2 10.1 Front Camera Replacement: 手順 2、 2の画像 2
    • Gently lift the screen up with your finger.
    • If the screen will not separate from the back cover, try repeating step 1.
  3. Samsung Galaxy Tab 2 10.1 Front Camera Replacement, Battery Disconnect: 手順 3、 1の画像 1
    • Using your fingers, remove the green tape covering the battery connector.
  4. Samsung Galaxy Tab 2 10.1 Front Camera Replacement: 手順 4、 3の画像 1 Samsung Galaxy Tab 2 10.1 Front Camera Replacement: 手順 4、 3の画像 2 Samsung Galaxy Tab 2 10.1 Front Camera Replacement: 手順 4、 3の画像 3
    この手順で使用する道具:
    Heavy-Duty Spudger
    • Insert the flat end of the heavy-duty spudger between the wires and underneath the battery connector. Carefully lift the black battery connector up to disconnect it from the motherboard.
    • The metal spudger shown in the photo is not recommended due to the possibility of an electrical short. Use an ESD-safe tool, such as a heavy-duty (nylon) spudger.
  5. Samsung Galaxy Tab 2 10.1 Front Camera Replacement, Front Camera: 手順 5、 2の画像 1 Samsung Galaxy Tab 2 10.1 Front Camera Replacement, Front Camera: 手順 5、 2の画像 2
    この手順で使用する道具:
    Heavy-Duty Spudger
  6. Samsung Galaxy Tab 2 10.1 Front Camera Replacement: 手順 6、 1の画像 1
    • Gently lift the gold cable connector with the flat end of the heavy-duty spudger to disconnect it from the device.
終わりに
8 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Amy Tsai
メンバー登録日: 01/30/15
1,993 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team 6-26, Amido Winter 2015 Cal Poly, Team 6-26, Amido Winter 2015人のメンバー
CPSU-AMIDO-W15S6G26
5 メンバー
14のガイドは作成済み
1 Guide Comment
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 19
今までの合計 1,812
