メインコンテンツにスキップ
Samsung Galaxy S7 Active Battery Replacement
必要な工具と部品
  1. Samsung Galaxy S7 Active Battery Replacement, Samsung Galaxy S7 Active Disassembly: 手順 1、 1の画像 1
    • Melt the adhesive on the screen by applying a blow dryer directly on the screen.
    • Your phone is hot, please do not touch it with your bare hand.
  2. Samsung Galaxy S7 Active Battery Replacement: 手順 2、 1の画像 1
    • Wedge the metal spudger in between the screen and the frame to begin separating them.
    • It would be easier to separate the screen from the sealing adhesive on the frame if you with more than one metal spudger.
    • Your phone might no longer be watertight after you reassemble it.
  3. Samsung Galaxy S7 Active Battery Replacement: 手順 3、 2の画像 1 Samsung Galaxy S7 Active Battery Replacement: 手順 3、 2の画像 2
    • Slide the metal spudger around the phone at least once.
    • It would be easier to slide your metal spudger if you apply the blow dryer to where you are currently sliding.
  4. Samsung Galaxy S7 Active Battery Replacement: 手順 4、 1の画像 1
    • Lift the screen up with your hands.
    • Please wash your hands thoroughly with hot water and soap after you finish.
  5. Samsung Galaxy S7 Active Battery Replacement, Battery: 手順 5、 1の画像 1
    • Use a Phillips #000 screwdriver to remove a single screw.
  6. Samsung Galaxy S7 Active Battery Replacement: 手順 6、 1の画像 1
    • Use tweezers to remove the small plastic cover you just unscrewed.
  7. Samsung Galaxy S7 Active Battery Replacement: 手順 7、 1の画像 1
    • Use tweezers to remove the other small plastic cover.
  8. Samsung Galaxy S7 Active Battery Replacement: 手順 8、 1の画像 1
    • Use a Phillips head #000 to take out the eleven screws marked in the photo.
  9. Samsung Galaxy S7 Active Battery Replacement: 手順 9、 1の画像 1
    • Use tweezers to disconnect the marked pieces from the motherboard.
  10. Samsung Galaxy S7 Active Battery Replacement: 手順 10、 1の画像 1
    • Use tweezers to take out the middle button and its connection to the motherboard.
  11. Samsung Galaxy S7 Active Battery Replacement: 手順 11、 3の画像 1 Samsung Galaxy S7 Active Battery Replacement: 手順 11、 3の画像 2 Samsung Galaxy S7 Active Battery Replacement: 手順 11、 3の画像 3
    • Use a metal spudger to pull the mid frame and battery off of the motherboard.
  12. Samsung Galaxy S7 Active Battery Replacement: 手順 12、 2の画像 1 Samsung Galaxy S7 Active Battery Replacement: 手順 12、 2の画像 2
    • Use a spudger to remove the battery from the midframe.
    • To install a new battery and adhesive, follow this guide.
終わりに
11 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Alexander Yazdani
メンバー登録日: 04/18/18
846 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team S18-G1, Livingston Spring 2018 Cal Poly, Team S18-G1, Livingston Spring 2018人のメンバー
CPSU-LIVINGSTON-S18S18G1
4 メンバー
15のガイドは作成済み
3 件のコメント
I would advise against using a metal spudger to remove the battery itself. While working at a device repair chain in the past, a coworker of mine punctured a battery with a metal spudger and destroyed the phone. Instead, use a sturdy plastic spudger to remove the battery. Otherwise, great guide!
Derek Margheim - 返信
I got the battery fixed but shattered my screen wish it was more informative on how to get out the screen
joshua hofer - 返信
Would using the Anti-clamp with heat gun be better option?
Kiriakos White - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 11
過去 30 日: 71
今までの合計 24,533
