メインコンテンツにスキップ
Samsung Galaxy S6 Active Battery Replacement
必要な工具と部品
  1. Samsung Galaxy S6 Active Battery Replacement, SIM Card: 手順 1、 2の画像 1 Samsung Galaxy S6 Active Battery Replacement, SIM Card: 手順 1、 2の画像 2
    • Insert your fingernail or a plastic opening tool into the pivot on the side of the SIM tray.
    • Pry open the tray to get it out of the socket.
  2. Samsung Galaxy S6 Active Battery Replacement: 手順 2、 1の画像 1
    • Remove the SIM tray with SIM card from the phone.
  3. Samsung Galaxy S6 Active Battery Replacement, Display Assembly: 手順 3、 3の画像 1 Samsung Galaxy S6 Active Battery Replacement, Display Assembly: 手順 3、 3の画像 2 Samsung Galaxy S6 Active Battery Replacement, Display Assembly: 手順 3、 3の画像 3
    • Heat the front face (sides, top, bottom) of the phone with the iOpener, a hair dryer, or a heat gun for 60 seconds to loosen the adhesive around the edge of the glass.
    • If using an iOpener, heat it in a microwave for thirty seconds.
    Heat the phone in the microwave??? I really hope you meant to say heat the iopener tool in the microwave.
    rusty bongwater - 返信
  4. Samsung Galaxy S6 Active Battery Replacement: 手順 4、 1の画像 1
    • Attach a suction cup to the lower half of the screen.
  5. Samsung Galaxy S6 Active Battery Replacement: 手順 5、 2の画像 1 Samsung Galaxy S6 Active Battery Replacement: 手順 5、 2の画像 2
    • Using the suction cup, pull gently the lower half of the panel.
    • If you pull too hard you may break the display. If you still feel resistance repeat Step 3, leaving the iOpener on longer.
    Pulling too* hard :)
    seth15599 - 返信
  6. Samsung Galaxy S6 Active Battery Replacement: 手順 6、 3の画像 1 Samsung Galaxy S6 Active Battery Replacement: 手順 6、 3の画像 2 Samsung Galaxy S6 Active Battery Replacement: 手順 6、 3の画像 3
    • Once you’ve opened a large enough gap, insert a plastic tool at the bottom, between the glass and the rest of frame of the phone.
    • Slide the plastic opening tool around the screen, prying the display gently away from the body
    My phone had a substantial amount of adhesive between the copper area on the back of the display assembly (see pic in step 10) and the frame (see pic in step 13). There was no way to have known that as I started to remove the glass, but this made it difficult to lift the glass up and eventually led to the glass cracking as I tried to work the plastic opening tool up along the side of the phone (about in the spot shown in the second picture of this step). In hindsight, I think it would have been extremely difficult to remove the front glass undamaged without first starting to separatie that adhesive from the frame, but I’m not sure what would have been the best way to do that. My guess is I would have needed to slide a tool with a thinner/sharper edge upward from the bottom while pulling on the suction cup to start separating the back of the display assembly from the frame, and worked on both that and the edges of the glass at the same time.
    Rob Asher - 返信
  7. Samsung Galaxy S6 Active Battery Replacement: 手順 7、 1の画像 1
    • Pull the lower half of the screen screen with the suction cup while holding down the frame of the phone to separate both components.
    • Only lift the lower part of the screen. It is connected with a clip to the top of the motherboard and can rip off if you pull too hard.
  8. Samsung Galaxy S6 Active Battery Replacement: 手順 8、 3の画像 1 Samsung Galaxy S6 Active Battery Replacement: 手順 8、 3の画像 2 Samsung Galaxy S6 Active Battery Replacement: 手順 8、 3の画像 3
    • Once the glass is off, you will see a small clip covering the screen connection to the motherboard at the top of the phone. Use tweezers to grab the clip by the crease on its side and pull it out.
  9. Samsung Galaxy S6 Active Battery Replacement: 手順 9、 1の画像 1
    • Undo the screen connection with a plastic tool.
    If possible, disconnect the battery BEFORE you undo the screen connector. The battery flex is on the left, just under the LCD cable assembly.
    Jeana Morales - 返信
  10. Samsung Galaxy S6 Active Battery Replacement: 手順 10、 1の画像 1
    • Remove the display assembly (LCD and Digitizer).
    All that copper/tin foil, whatever it is, stayed glued to the case and tore off the screen. I hope it isn’t important. What is it for anyways?
    Reed Deemer - 返信
    Good Question. Mine ripped a little bit 2.
    floris brocaar -
    Probably heat displacement, you’ll find them on the back of most Samsung OEM LCD assemblies & high quality replacements. It’s probably not a big deal if you tear it, after all where’s the heat supposed to go from there? Pat yourself on the back for getting the LCD & glass up in one piece, don’t be surprised if nobody else shares your enthusiasm.
    NxG Walpole - 返信
  11. Samsung Galaxy S6 Active Battery Replacement, Battery: 手順 11、 2の画像 1 Samsung Galaxy S6 Active Battery Replacement, Battery: 手順 11、 2の画像 2
    • Use the Phillips Head Screwdriver sized PH000 to remove the sixteen 4mm screws from the frame.
    PH00 size screwdriver fit the screw heads better on my phone.
    Missing intermediate step: the screw just above the battery holds a little plastic cover that hides the battery connector. Take the cover out and carefully disconnect the battery using the tweezers.
    Sergiu Partenie - 返信
  12. Samsung Galaxy S6 Active Battery Replacement: 手順 12、 1の画像 1
    • Put a little pressure on the top, on the bottom, and on the sides of the phone to separate the rear case.
    • You will hear the clips start undoing themselves.
  13. Samsung Galaxy S6 Active Battery Replacement: 手順 13、 2の画像 1 Samsung Galaxy S6 Active Battery Replacement: 手順 13、 2の画像 2
    • Once all the clips have popped, pull out the rear case to separate it from the frame with the battery.
    • The battery will be on the back side of this frame.
  14. Samsung Galaxy S6 Active Battery Replacement: 手順 14、 1の画像 1
    • Insert a plastic opening tool on the side of the frame and pull out the battery.
    The battery was glued quite well on mine, I had to slowly go around the whole edge about 3 times. Exercise care at this operation, especially if the old battery is swollen.
    To loose the battery it helps to add isopropyl alcohol drop by drop with a syringe all around the batery and on both sides. Give some time to the alcohol to do its job. You may try to heat gently as well.
    Jose Luis - 返信
  15. Samsung Galaxy S6 Active Battery Replacement: 手順 15、 2の画像 1 Samsung Galaxy S6 Active Battery Replacement: 手順 15、 2の画像 2
    • Remove the battery from the frame.
終わりに
After completing this guide, calibrate your newly-installed battery.
42 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Lucia Valbuena
メンバー登録日: 02/15/17
2,412 ポイント
8のガイドは作成済み
チーム
USF Tampa, Team 1-5, Sullivan Spring 2017 USF Tampa, Team 1-5, Sullivan Spring 2017人のメンバー
USFT-SULLIVAN-S17S1G5
3 メンバー
25のガイドは作成済み
20 件のコメント
thank you for the information on how to dissemble this device Samsung Galaxy S6 Active
Eleyson Cubias - 返信
You have GOT to be kidding me....... major surgery to just remove power so that I can reboot the phone. Guess I will just have to wait until all the battery power runs out. 2 or 3 days? Uggghhhhhhhhh
Joe Besta - 返信
You can perform a forced reboot manually. Simultaneously hold down the volume down button and the power button for 10-20 seconds. This will reboot your phone without losing anything.
Kirk Baker - 返信
Looks like the difficult part is the removal of the LCD assembly. What type of adhesive can be used on the LCD screen to glue back on phone?
Francisco Roque - 返信
Never &&^&^$^ answer…
cristhian cruz - 返信
Very good information
Thank
Daniel Carson - 返信
HARD RESET: Press the Power button and the Down Volume for 20 Seconds.
This simulates taking the battery out and back in.
Asael Paniagua - 返信
I do want to mention that the OLED screen is VERY fragile and you really shouldn’t attempt this without ordering a new screen. I work at a repair shop and we’ve refused people at the door because the repair is near impossible. The OLED is almost designed to break when you pull the assembly apart.
Shraeder - 返信
Any way you can show how to put it back together, specially the part were heat is applied?
Yasser Aiq - 返信
Slide in a playing card to loosen the adhesive. If its warm enough it will easily slide off. Shouldn’t take experienced professionals more than an hour or so. Reapply a light layer of b700 and clamp.
Rocket Repair - 返信
Wait so how would you reattach the front screen if the adhesive is gone? I’m making sure beforehand because my S6 Active is having a lot of battery problems (I knew I should’ve bought an iPhone) but I want to be 100% sure before I perform the repair. How do you reattach the front screen?
Hyrum Tripp - 返信
you will need to purchase replacement adhesive. I also wouldn’t recommend opening the device unless you have lots of experience. the AMOLED display is incredibly fragile and will break 9 times out of 10 when opening the phone.
Shraeder -
Great guide. I changed the battery with no problem at all thanks to it. Thank you very much.
Maciej Fogiel - 返信
Followed you instructions to the tee. Very pleased with how easy it really is. Just a little patience with the light tug, and it lifted up enough to place the slider and slowly pry it apart. I was able to save the inner sheet. I paid $15 on Amazon for a battery and replacement tool kit. Took me about 15 minutes to replace. Phone company wanted $45 for battery and another $65 to replace. Gotta say.. thanks a bunch for saving me $$.
Jose Gonzalez - 返信
There wasn’t any comment on the gold foil stuff on the back of the display… mine didn’t want to come off with it. What do I do in that situation?
Amber Chapell - 返信
Made it much easier to fix this phone
I.H Tech - 返信
Looks a little complicated…how do you put it back together? I have one and my battery bad so I have to do this and replace the battery?..How?
Hannah Elizabeth Marie Miller - 返信
i changed the battery thanx to this tutorial. But still my phone shut down as soon as i unplugged it from the charger. The battery goes down from 100% to 0% :-( Is the new battery not working? or something else ?
Velléda Blanc - 返信
Success! Due to poor battery capacity. I ordered the $15 HDCKU repair kit from Amazon, then I started reading. The repair process scared me about breaking the screen but I pushed on being extremely careful. Since the battery was swollen half the work of removing the screen was half done since one side was pushed out. This website was an invaluable guide. I also watched a couple of videos. The only thing that was a real problem was getting that ultra tiny battery connector to snap in and stay. I probably spent 10 minutes on that one item. Total time was about 30 minutes beginning to end. The battery started out at 53%. I exactly followed the calibration routine. My wife is very happy now that her phone is back in business with full battery capacity. I dread the day when I have to replace the battery in my Galaxy S10.
rcflyer65 - 返信
Sucessfully followed your instructions to replace battery in my s6 active. Notes: I had to heat with hairdryer about 8 times to get glue to soften enough to lift. The thin metal skin on the back of the screen (the digitizer??) also did not lift with the screen and ripped in one corner. I carefully proceeded as instructed regardless. Also, after snapping the battery frame and back of phone frame apart, the battery frame did not want to remove, had to pry pretty hard to get it to come out, which made me feel I was potentially damaging or disconnecting something else. The battery is also glued in, so has to be lifted/peeled off as well. Regardless, your photos allowed me to confidently proceed and successfully put new battery in. Screen is working, phone is on wireless charger now to see if my repair was successful. Thanks for the instructional!
redbrew - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 20
過去 30 日: 74
今までの合計 64,030
