メインコンテンツにスキップ
Samsung Galaxy S6 Active Battery Replacement
必要な工具と部品
  1. Samsung Galaxy S6 Active Battery Replacement, SIM Card: 手順 1、 2の画像 1 Samsung Galaxy S6 Active Battery Replacement, SIM Card: 手順 1、 2の画像 2
    • Insert your fingernail or a plastic opening tool into the pivot on the side of the SIM tray.
    • Pry open the tray to get it out of the socket.
  2. Samsung Galaxy S6 Active Battery Replacement: 手順 2、 1の画像 1
    • Remove the SIM tray with SIM card from the phone.
  3. Samsung Galaxy S6 Active Battery Replacement, Display Assembly: 手順 3、 3の画像 1 Samsung Galaxy S6 Active Battery Replacement, Display Assembly: 手順 3、 3の画像 2 Samsung Galaxy S6 Active Battery Replacement, Display Assembly: 手順 3、 3の画像 3
    • Heat the front face (sides, top, bottom) of the phone with the iOpener, a hair dryer, or a heat gun for 60 seconds to loosen the adhesive around the edge of the glass.
    • If using an iOpener, heat it in a microwave for thirty seconds.
  4. Samsung Galaxy S6 Active Battery Replacement: 手順 4、 1の画像 1
    • Attach a suction cup to the lower half of the screen.
  5. Samsung Galaxy S6 Active Battery Replacement: 手順 5、 2の画像 1 Samsung Galaxy S6 Active Battery Replacement: 手順 5、 2の画像 2
    • Using the suction cup, pull gently the lower half of the panel.
    • If you pull too hard you may break the display. If you still feel resistance repeat Step 3, leaving the iOpener on longer.
  6. Samsung Galaxy S6 Active Battery Replacement: 手順 6、 3の画像 1 Samsung Galaxy S6 Active Battery Replacement: 手順 6、 3の画像 2 Samsung Galaxy S6 Active Battery Replacement: 手順 6、 3の画像 3
    • Once you’ve opened a large enough gap, insert a plastic tool at the bottom, between the glass and the rest of frame of the phone.
    • Slide the plastic opening tool around the screen, prying the display gently away from the body
  7. Samsung Galaxy S6 Active Battery Replacement: 手順 7、 1の画像 1
    • Pull the lower half of the screen screen with the suction cup while holding down the frame of the phone to separate both components.
    • Only lift the lower part of the screen. It is connected with a clip to the top of the motherboard and can rip off if you pull too hard.
  8. Samsung Galaxy S6 Active Battery Replacement: 手順 8、 3の画像 1 Samsung Galaxy S6 Active Battery Replacement: 手順 8、 3の画像 2 Samsung Galaxy S6 Active Battery Replacement: 手順 8、 3の画像 3
    • Once the glass is off, you will see a small clip covering the screen connection to the motherboard at the top of the phone. Use tweezers to grab the clip by the crease on its side and pull it out.
  9. Samsung Galaxy S6 Active Battery Replacement: 手順 9、 1の画像 1
    • Undo the screen connection with a plastic tool.
  10. Samsung Galaxy S6 Active Battery Replacement: 手順 10、 1の画像 1
    • Remove the display assembly (LCD and Digitizer).
  11. Samsung Galaxy S6 Active Battery Replacement, Battery: 手順 11、 2の画像 1 Samsung Galaxy S6 Active Battery Replacement, Battery: 手順 11、 2の画像 2
    • Use the Phillips Head Screwdriver sized PH000 to remove the sixteen 4mm screws from the frame.
  12. Samsung Galaxy S6 Active Battery Replacement: 手順 12、 1の画像 1
    • Put a little pressure on the top, on the bottom, and on the sides of the phone to separate the rear case.
    • You will hear the clips start undoing themselves.
  13. Samsung Galaxy S6 Active Battery Replacement: 手順 13、 2の画像 1 Samsung Galaxy S6 Active Battery Replacement: 手順 13、 2の画像 2
    • Once all the clips have popped, pull out the rear case to separate it from the frame with the battery.
    • The battery will be on the back side of this frame.
  14. Samsung Galaxy S6 Active Battery Replacement: 手順 14、 1の画像 1
    • Insert a plastic opening tool on the side of the frame and pull out the battery.
  15. Samsung Galaxy S6 Active Battery Replacement: 手順 15、 2の画像 1 Samsung Galaxy S6 Active Battery Replacement: 手順 15、 2の画像 2
    • Remove the battery from the frame.
終わりに
After completing this guide, calibrate your newly-installed battery.
42 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Lucia Valbuena
メンバー登録日: 02/15/17
2,412 ポイント
8のガイドは作成済み
チーム
USF Tampa, Team 1-5, Sullivan Spring 2017 USF Tampa, Team 1-5, Sullivan Spring 2017人のメンバー
USFT-SULLIVAN-S17S1G5
3 メンバー
25のガイドは作成済み
20 件のコメント
thank you for the information on how to dissemble this device Samsung Galaxy S6 Active
Eleyson Cubias - 返信
You have GOT to be kidding me....... major surgery to just remove power so that I can reboot the phone. Guess I will just have to wait until all the battery power runs out. 2 or 3 days? Uggghhhhhhhhh
Joe Besta - 返信
You can perform a forced reboot manually. Simultaneously hold down the volume down button and the power button for 10-20 seconds. This will reboot your phone without losing anything.
Kirk Baker - 返信
Looks like the difficult part is the removal of the LCD assembly. What type of adhesive can be used on the LCD screen to glue back on phone?
Francisco Roque - 返信
Never &&^&^$^ answer…
cristhian cruz - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 20
過去 30 日: 74
今までの合計 64,030
