この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
How to replace broken display assembly without middle frame.
必要な工具と部品
ビデオの概要
Pry with a plastic opening tool, or your fingernail, in the divot to the left of the rear-facing camera, near the power button.
Use the flat end of a spudger, or your fingernail, to press the microSD card slightly deeper into its slot until you hear a click.
After the click, release the card and it will pop out of its slot.
Remove the microSD card.
Insert a plastic opening tool, or your finger, into the notch of the battery compartment and lift the battery upward.
Remove the battery from your phone.
Use a plastic opening tool, or your fingernail, to press the SIM card slightly deeper into its slot until you hear a click.
Remove the SIM card.
Remove the nine 4.0 mm Phillips #00 screws securing the midframe to the display assembly.
Use the flat end of a spudger to disconnect the USB board connector.
Disconnect the front-facing camera cable connector.
Disconnect the earpiece speaker assembly cable connector.
Use a heat gun or hair dryer and warm the digitizer glass.
If the glass is broken, put some scotch tape.
Use an utility knife and make a room at upper side between the glass and the frame.
Continue with the separating with a plastic tools (plastic spudger or something similar).
Clean the frame from the old adhesive tape and install a new one.
Preferably, use adhesive sticker which is made for the model.
When you install the new adhesive tape be careful, don't cover the holes for the front camera, light sensor, etc.
Start with reassembling.
27 の人々がこのガイドを完成させました。
