メインコンテンツにスキップ
Samsung Galaxy S21 Wireless Charging Coil Replacement
必要条件のみ
この修理ガイドは、他のガイドの前提条件として使用されます。それ自体は不完全で、単独で使用されることはありません。
  1. Samsung Galaxy S21 Wireless Charging Coil Replacement, Unfasten the motherboard bracket: 手順 1、 2の画像 1 Samsung Galaxy S21 Wireless Charging Coil Replacement, Unfasten the motherboard bracket: 手順 1、 2の画像 2
    • Use a Phillips screwdriver to remove the five 4 mm-long screws securing the motherboard bracket to the frame.
  2. Samsung Galaxy S21 Wireless Charging Coil Replacement, Unclip the motherboard bracket: 手順 2、 2の画像 1 Samsung Galaxy S21 Wireless Charging Coil Replacement, Unclip the motherboard bracket: 手順 2、 2の画像 2
    この手順で使用する道具:
    • Use a pair of tweezers to gently pull up and unclip the motherboard bracket from the frame.
    • Do not completely remove the bracket yet, as it's still attached to the wireless charging coil.
  3. Samsung Galaxy S21 Wireless Charging Coil Replacement, Disconnect the battery: 手順 3、 2の画像 1 Samsung Galaxy S21 Wireless Charging Coil Replacement, Disconnect the battery: 手順 3、 2の画像 2
    • While using tweezers, or your fingers, to hold the motherboard bracket out of the way, use a spudger to pry up the battery press connector.
    • Take care to pry only under the edge of the connector to prevent damaging the socket itself and surrounding components.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  4. Samsung Galaxy S21 Wireless Charging Coil Replacement, Disconnect the wireless charging coil: 手順 4、 2の画像 1 Samsung Galaxy S21 Wireless Charging Coil Replacement, Disconnect the wireless charging coil: 手順 4、 2の画像 2
    • While holding the motherboard bracket out of the way, use a spudger to pry up and disconnect the wireless charging coil's press connector.
  5. Samsung Galaxy S21 Wireless Charging Coil Replacement, Unfasten the loudspeaker: 手順 5、 2の画像 1 Samsung Galaxy S21 Wireless Charging Coil Replacement, Unfasten the loudspeaker: 手順 5、 2の画像 2
    • Use a Phillips screwdriver to remove the six 4 mm-long screws securing the loudspeaker to the frame.
  6. Samsung Galaxy S21 Wireless Charging Coil Replacement, Disconnect the loudspeaker: 手順 6、 2の画像 1 Samsung Galaxy S21 Wireless Charging Coil Replacement, Disconnect the loudspeaker: 手順 6、 2の画像 2
    • Insert the point of a spudger into the notch in the top-left corner of the loudspeaker and pry up to release the clips holding it in place.
  7. Samsung Galaxy S21 Wireless Charging Coil Replacement, Remove the wireless charging coil: 手順 7、 2の画像 1 Samsung Galaxy S21 Wireless Charging Coil Replacement, Remove the wireless charging coil: 手順 7、 2の画像 2
    • Remove the wireless charging coil.
終わりに
作成者
2人の作成者と共同で作成されました。
Alex Diaz-Kokaisl
メンバー登録日: 01/16/22
162,014 ポイント
769のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
118 メンバー
19,418のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 5
今までの合計 64
