メインコンテンツにスキップ
Samsung Galaxy S III SIM Card Replacement
必要な工具と部品
  1. Samsung Galaxy S III SIM Card Replacement, Rear Case: 手順 1、 2の画像 1 Samsung Galaxy S III SIM Card Replacement, Rear Case: 手順 1、 2の画像 2
    • The following four steps can be accomplished without a plastic opening tool. However, it's recommended to use a tool to best avoid breaking any clips along the perimeter of the rear case.
    • Insert a plastic opening tool or fingernail into the notch in the gap between the rear case and the rest of the phone, located at the top of the device.
    • Gently twist the opening tool to disconnect the clips securing the top of the rear case.
  2. Samsung Galaxy S III SIM Card Replacement: 手順 2、 2の画像 1 Samsung Galaxy S III SIM Card Replacement: 手順 2、 2の画像 2
    • Slide the plastic opening tool left along the top edge and repeat the twisting motion to widen the gap between the rear case and the phone.
  3. Samsung Galaxy S III SIM Card Replacement: 手順 3、 2の画像 1 Samsung Galaxy S III SIM Card Replacement: 手順 3、 2の画像 2
    • Continue to move the plastic opening tool around the perimeter of the top left corner, gently prying up along the rear case.
  4. Samsung Galaxy S III SIM Card Replacement: 手順 4、 2の画像 1 Samsung Galaxy S III SIM Card Replacement: 手順 4、 2の画像 2
    • Pry along the top right side, and continue prying down the right side of the rear case.
  5. Samsung Galaxy S III SIM Card Replacement: 手順 5、 2の画像 1 Samsung Galaxy S III SIM Card Replacement: 手順 5、 2の画像 2
    • Lift up and remove the rear case from the phone.
    • You may need to peel the case up to separate it from any clips still holding it to the bottom of the phone.
    very easy to follow instructions clear and concise
    Deric JONES - 返信
  6. Samsung Galaxy S III SIM Card Replacement, Battery: 手順 6、 2の画像 1 Samsung Galaxy S III SIM Card Replacement, Battery: 手順 6、 2の画像 2
    • This step can be accomplished without the need of a plastic opening tool. Just use your finger if you want to.
    • Wedge a plastic opening tool into the small notch above the battery.
    • Pry the battery up out of its recess.
  7. Samsung Galaxy S III SIM Card Replacement: 手順 7、 2の画像 1 Samsung Galaxy S III SIM Card Replacement: 手順 7、 2の画像 2
    • Remove the battery.
  8. Samsung Galaxy S III SIM Card Replacement, SIM Card: 手順 8、 3の画像 1 Samsung Galaxy S III SIM Card Replacement, SIM Card: 手順 8、 3の画像 2 Samsung Galaxy S III SIM Card Replacement, SIM Card: 手順 8、 3の画像 3
    • Using your fingernail, push the SIM card slightly deeper into its slot, until you hear a click.
    • After the click, release the card and it will pop out of its slot.
    • For reassembly, push the SIM card into the slot until it clicks in place.
  9. Samsung Galaxy S III SIM Card Replacement: 手順 9、 3の画像 1 Samsung Galaxy S III SIM Card Replacement: 手順 9、 3の画像 2 Samsung Galaxy S III SIM Card Replacement: 手順 9、 3の画像 3
    • Use your thumb to slide enough of the SIM card out of its slot to grab ahold of it.
    • Grasp and remove the SIM card away from the phone.
終わりに
41 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Walter Galan
701,352 ポイント
1,203のガイドは作成済み
3 件のコメント
My Samsung Galaxy S III does not seem to have a sim card. I bought it through Sprint around 2011 time frame. Do you know if it has an internal sim card that can not be replaced?
Joe - 返信
Sprint and Verizon are CDMA (embedded SIM) while AT&T and T-Mobile is GSM.
J Fors -
i was trying to find the sims card and insted i pulled the slot loose from the phone can it be fixed or replaced
sylviahinkle - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 14
過去 30 日: 83
今までの合計 88,045
