メインコンテンツにスキップ
Samsung Galaxy S III Rear Case Replacement
必要な工具と部品
  1. Samsung Galaxy S III Rear Case Replacement, Rear Case: 手順 1、 2の画像 1 Samsung Galaxy S III Rear Case Replacement, Rear Case: 手順 1、 2の画像 2
    • The following four steps can be accomplished without a plastic opening tool. However, it's recommended to use a tool to best avoid breaking any clips along the perimeter of the rear case.
    • Insert a plastic opening tool or fingernail into the notch in the gap between the rear case and the rest of the phone, located at the top of the device.
    • Gently twist the opening tool to disconnect the clips securing the top of the rear case.
  2. Samsung Galaxy S III Rear Case Replacement: 手順 2、 2の画像 1 Samsung Galaxy S III Rear Case Replacement: 手順 2、 2の画像 2
    • Slide the plastic opening tool left along the top edge and repeat the twisting motion to widen the gap between the rear case and the phone.
  3. Samsung Galaxy S III Rear Case Replacement: 手順 3、 2の画像 1 Samsung Galaxy S III Rear Case Replacement: 手順 3、 2の画像 2
    • Continue to move the plastic opening tool around the perimeter of the top left corner, gently prying up along the rear case.
  4. Samsung Galaxy S III Rear Case Replacement: 手順 4、 2の画像 1 Samsung Galaxy S III Rear Case Replacement: 手順 4、 2の画像 2
    • Pry along the top right side, and continue prying down the right side of the rear case.
  5. Samsung Galaxy S III Rear Case Replacement: 手順 5、 2の画像 1 Samsung Galaxy S III Rear Case Replacement: 手順 5、 2の画像 2
    • Lift up and remove the rear case from the phone.
    • You may need to peel the case up to separate it from any clips still holding it to the bottom of the phone.
    very easy to follow instructions clear and concise
    Deric JONES - 返信
終わりに
To reassemble your device, simply press the rear case back onto the body of the phone and squeeze it in place, until all of the clips snap in place.
25 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Walter Galan
701,310 ポイント
1,203のガイドは作成済み
コメント 1 件
I do it in less than 2 seconds using a fingernail with one swift move (pulling the notch up) and no clips have ever broken because of it.
Krzeszny - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 23
今までの合計 13,938
