このバージョンは誤った内容を含んでいる可能性があります。最新の承認済みスナップショットに切り替えてください。
必要な工具と部品
この手順は未翻訳です。 翻訳を手伝う。
Free the clasps along the battery slot. And the push the front assembly out from middle housing with effort.
We can see the USB board but we can't tear it down directly. Because 1. The USB board flex connector is connecting on the back of the motherboard. 2. If want to remove motherboard, the LCD screen need to be removed at first. 3. The USB board assembly comes with two touch keys together but they are placed under the touch panel.
So we have to remove the motherboard and LCD screen at first next.
この手順は未翻訳です。 翻訳を手伝う。
Cut the adhesive under the screen, release the connectors and remove the LCD screen. You can see more details when remove the LCD screen at Samsung Galaxy Note 4 LCD screen replacement guide.
54 の人々がこのガイドを完成させました。
8 件のコメント
charging port from 910C will be suitable to 910F model? Pls answer
After replacing USB ass'y, my AT&T phone does not recognize the Sim being installed.
Any suggestions?
Dan
