この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Follow the steps in order to replace your battery.
If your battery is swollen, take appropriate precautions.
必要な工具と部品
Insert a fingernail or plastic opening tool in the gap between the rear case and the base of the phone.
Slide your fingernail or plastic opening tool along the edge of the rear case.
Lift the case gently from the base.
Insert a fingernail or plastic opening tool into the small gap between the battery and the phone base.
Lift the battery out of its recess.
45 の人々がこのガイドを完成させました。
