メインコンテンツにスキップ
Samsung Galaxy Note 10.1 Front-Facing Camera Replacement
必要な工具と部品
  1. Samsung Galaxy Note 10.1 Front-Facing Camera Replacement, Removing the Top Piece: 手順 1、 3の画像 1 Samsung Galaxy Note 10.1 Front-Facing Camera Replacement, Removing the Top Piece: 手順 1、 3の画像 2 Samsung Galaxy Note 10.1 Front-Facing Camera Replacement, Removing the Top Piece: 手順 1、 3の画像 3
    • This is the back of the device and where you willl begin to take it apart
    • It is necessary to remove the silver piece covering the camera first before removing the bigger back piece.
    • Use the plastic opening tools to pry along the indicated box.
    • Lift up the silver piece to reveal the rest of the back cover.
  2. Samsung Galaxy Note 10.1 Front-Facing Camera Replacement, Removing the Back Cover: 手順 2、 3の画像 1 Samsung Galaxy Note 10.1 Front-Facing Camera Replacement, Removing the Back Cover: 手順 2、 3の画像 2 Samsung Galaxy Note 10.1 Front-Facing Camera Replacement, Removing the Back Cover: 手順 2、 3の画像 3
    • Unscrew the three screws indicated by the red circles with the Philips #00 screwdriver.
    • Using the plastic opening tools pry along the bottom of the device, moving to the sides of the cover to the top.
    • Remove the back cover.
    • At this point use anti-static gloves or do NOT take it apart on carpet.
  3. Samsung Galaxy Note 10.1 Front-Facing Camera Replacement, Removing the Camera: 手順 3、 3の画像 1 Samsung Galaxy Note 10.1 Front-Facing Camera Replacement, Removing the Camera: 手順 3、 3の画像 2 Samsung Galaxy Note 10.1 Front-Facing Camera Replacement, Removing the Camera: 手順 3、 3の画像 3
    • Start by lifting the white connector to remove the part indicated by the red polygon.
    • Gently pry along the camera hub to lift it out of its location.
    • This is your camera. Replace it with the new part.
  4. Samsung Galaxy Note 10.1 Front-Facing Camera Replacement, Front-Facing Camera: 手順 4、 3の画像 1 Samsung Galaxy Note 10.1 Front-Facing Camera Replacement, Front-Facing Camera: 手順 4、 3の画像 2 Samsung Galaxy Note 10.1 Front-Facing Camera Replacement, Front-Facing Camera: 手順 4、 3の画像 3
    • Now that you have removed the rear-facing camera, you can access the front-facing camera.
    • To remove the front-facing camera, start by lifting the white connector to remove the part indicated by the marker.
    • Gently pull the front-facing camera out of its casing.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Rachel Dykes
メンバー登録日: 11/04/19
205 ポイント
2のガイドは作成済み
チーム
Idaho State University, Team S1-G4, Watkins Fall 2019 Idaho State University, Team S1-G4, Watkins Fall 2019人のメンバー
ISU-WATKINS-F19S1G4
3 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 5
今までの合計 348
