メインコンテンツにスキップ
Samsung Galaxy Fame S6812i LCD Screen Replacement
必要な工具と部品
  1. Samsung Galaxy Fame S6812i LCD Screen Replacement, Remove the Battery Cover: 手順 1、 2の画像 1 Samsung Galaxy Fame S6812i LCD Screen Replacement, Remove the Battery Cover: 手順 1、 2の画像 2
    • Locate the small indent in the top of the device and use your nails or the plastic opening tool to separate the cover from the mid-frame.
  2. Samsung Galaxy Fame S6812i LCD Screen Replacement, Remove the Battery: 手順 2、 2の画像 1 Samsung Galaxy Fame S6812i LCD Screen Replacement, Remove the Battery: 手順 2、 2の画像 2
    • Locate the indent on the bottom left corner of the battery compartment. Use your fingers or the plastic opening tool to lift the battery from the device.
  3. Samsung Galaxy Fame S6812i LCD Screen Replacement, Remove the Mid-Frame: 手順 3、 3の画像 1 Samsung Galaxy Fame S6812i LCD Screen Replacement, Remove the Mid-Frame: 手順 3、 3の画像 2 Samsung Galaxy Fame S6812i LCD Screen Replacement, Remove the Mid-Frame: 手順 3、 3の画像 3
    • Remove the five 3mm screws along the top and bottom edges of the device with the Philips #00 screwdriver.
    • One of these will be hidden under a piece of reflective foil. Breaking this will void the warranty.
    • Use the plastic removal tool to work pry the mid-frame from the device.
    • This may take some effort, so try working around the edges slowly as to not break anything.
  4. Samsung Galaxy Fame S6812i LCD Screen Replacement, Unplug LCD Screen from the Motherboard: 手順 4、 3の画像 1 Samsung Galaxy Fame S6812i LCD Screen Replacement, Unplug LCD Screen from the Motherboard: 手順 4、 3の画像 2 Samsung Galaxy Fame S6812i LCD Screen Replacement, Unplug LCD Screen from the Motherboard: 手順 4、 3の画像 3
    • Carefully use the pointed end of the spudger to disconnect the ribbon connections on the motherboard.
  5. Samsung Galaxy Fame S6812i LCD Screen Replacement, Remove the Motherboard: 手順 5、 1の画像 1
    • Wedge the plastic opening tool between the motherboard and front plate to dismount the motherboard and chassis from the front plate of the phone.
  6. Samsung Galaxy Fame S6812i LCD Screen Replacement, Remove Damaged LCD Screen: 手順 6、 3の画像 1 Samsung Galaxy Fame S6812i LCD Screen Replacement, Remove Damaged LCD Screen: 手順 6、 3の画像 2 Samsung Galaxy Fame S6812i LCD Screen Replacement, Remove Damaged LCD Screen: 手順 6、 3の画像 3
    • Use one side of the tweezers to pry the LCD off of the front plate of the phone.
    • Work in a clean environment and do not touch the inside of the plastic screen cover or the face of the new LCD Screen. These cannot be cleaned once the device is reassembled.
終わりに
7 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Taylor
メンバー登録日: 01/30/15
1,165 ポイント
5のガイドは作成済み
チーム
USF Tampa, Team 16-6, Watkins Winter 2015 USF Tampa, Team 16-6, Watkins Winter 2015人のメンバー
USFT-WATKINS-W15S16G6
2 メンバー
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 3
今までの合計 1,907
