必要な工具と部品
ビデオの概要
- 充電ケースの解体はとても簡単です。バッテリーはモジュールで、アクセスと交換が簡単にできます。
- わずかな外観のダメージを伴ってしまうバズの開口作業には力が必要です。これは、気が遠くなるような最初の修理手順です。
- バズはセミモジュールです。メインの回路基板のアクセスは簡単で、プラスネジで固定されています。しかしながら、バッテリーの接続は半田付けされています。
- バズのドライバーの交換は非常に手間と苦労のかかるものとなりますが、実際のところアクセス不可能です。そして破壊的解体となる可能性が高いでしょう。
まとめ
リペアビリティのスコア
3
10点中3点のリペアビリティ
(10点が最も修理しやすい指標です)
(10点が最も修理しやすい指標です)
以下の翻訳者の皆さんにお礼を申し上げます:
en jp
100%
翻訳を始める ›
10 件のコメント
Samsung making less repairable earbuds: “It’s evolving, just backwards.”
Ethan Zuo - 返信
Is dropped one ear bud few times and touch control stopped working one it ..except that everything works fine even the volume control…how to fix it?
Jakub Serafin - 返信
I love how easy the case is to take apart, however I cannot seem to locate a replacement battery for the charging case. Any idea where I could locate one?
Trevor Reed - 返信
Looks like the Galaxy Watch 46mm battery!
https://www.reichelt.com/de/en/battery-f...
I haven't tried it tho, but will have to soon because my Buds Pro case got water damaged. Thankfully it charges the buds but not the case, so I'll try to replace the battery and see if that helps.
Oscar de León -
Found the one! After disassembling my case I could check the actual part number
https://www.ebay.com/itm/354134695747?ha...
Oscar de León -
Is it possible to buy just the battery for the SM-R190 case?
I left my case and buds in washing machine. The ear buds have dried out and seem to work fine now. I had to open the case and dry it out and clean contacts. The case and buds charge to 100%, but when I disconnect USB charger, the case charge quicky drops to zero (in minutes). I am hoping it is just the battery that needs replacing. The buds will charge in the case.
Glenn Lindsay - 返信
Hi,
I have copied link posted by Oscar de Léon and ordered the battery. He has had EXACTLY the same problem as me.
Thanks, I hope that solves my problem, i.e. it is not something else.
Glenn Lindsay - 返信
Struggling to replace the magnet after dropping and the case opened.
I can still charge the case/buds but the case doesn’t snap shut anymore and stays slightly open so the case discharges quickly but the buds stay good. 🙏
Andrew McKelvey - 返信
where to find the charging connector
ayub shaikh - 返信
Does anyone else have tuis issue? I have intermittent right bud charging issues. It appears that the connection is not being made. I found if I turn the charging case upside down, and tap it it will disconnect from my phone and is starts charging. But bump it later and it connects to phone and stops charging.
David Johnson - 返信
