メインコンテンツにスキップ
Samsung Galaxy A70 Back Cover Replacement
必要な工具と部品
  1. Samsung Galaxy A70 Back Cover Replacement, Soften the adhesive: 手順 1、 1の画像 1
    • Switch off your Galaxy A70.
    • Heat an iOpener and use it to soften the adhesive beneath the back cover. Apply the iOpener for at least two minutes. You might want to repeat this step several times during the back cover removal.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the AMOLED display and internal battery are both susceptible to heat damage.
  2. Samsung Galaxy A70 Back Cover Replacement, Create a gap: 手順 2、 2の画像 1 Samsung Galaxy A70 Back Cover Replacement, Create a gap: 手順 2、 2の画像 2
    • Apply a suction cup to the back of the phone, as close as possible to the center of the right edge.
    • Pull on the suction cup to create a gap between the back cover and the frame.
    • Insert an opening pick into the gap.
  3. Samsung Galaxy A70 Back Cover Replacement, Slice the adhesive: 手順 3、 3の画像 1 Samsung Galaxy A70 Back Cover Replacement, Slice the adhesive: 手順 3、 3の画像 2 Samsung Galaxy A70 Back Cover Replacement, Slice the adhesive: 手順 3、 3の画像 3
    • Slide the opening pick along the edge to the bottom right corner.
    • Leave the opening pick in its place to prevent the adhesive from resealing.
    • Once you have inserted an opening pick, feel free to remove the suction cup or continue to use it for a better grip during the removal procedure.
  4. Samsung Galaxy A70 Back Cover Replacement: 手順 4、 3の画像 1 Samsung Galaxy A70 Back Cover Replacement: 手順 4、 3の画像 2 Samsung Galaxy A70 Back Cover Replacement: 手順 4、 3の画像 3
    • Insert a second opening pick underneath the bottom right corner of the back cover.
    • Slide the opening pick along the edge to the top right corner.
    • If you have trouble with cutting, you can use the iOpener again to soften the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  5. Samsung Galaxy A70 Back Cover Replacement: 手順 5、 2の画像 1 Samsung Galaxy A70 Back Cover Replacement: 手順 5、 2の画像 2
    • Insert a third opening pick underneath the top right corner of the back cover.
    • Slide the tip of the opening pick along the top edge of the phone to cut the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  6. Samsung Galaxy A70 Back Cover Replacement: 手順 6、 3の画像 1 Samsung Galaxy A70 Back Cover Replacement: 手順 6、 3の画像 2 Samsung Galaxy A70 Back Cover Replacement: 手順 6、 3の画像 3
    • Insert a fourth opening pick underneath the top left corner.
    • Slide the opening pick along the left edge of your phone to cut the adhesive.
  7. Samsung Galaxy A70 Back Cover Replacement: 手順 7、 2の画像 1 Samsung Galaxy A70 Back Cover Replacement: 手順 7、 2の画像 2
    • Insert a fifth opening pick underneath the bottom left corner.
    • Slide it along the the bottom edge to cut the remaining adhesive.
  8. Samsung Galaxy A70 Back Cover Replacement, Remove the back cover: 手順 8、 1の画像 1
    • Remove the back cover.
    • After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond — a stack of heavy books works well.
終わりに
Secure the new back cover with pre-cut adhesive or double-sided adhesive tape.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
12 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Adriana Zwink
メンバー登録日: 12/18/19
48,265 ポイント
167のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
135 メンバー
16,817のガイドは作成済み
コメント 1 件
i have a problem in my A70 , i replaced the screen , then after a week the back cover started to open from the down left side opposite to camera side .
once this happens , the screen turn off but phone is alive and receiving calls and messages.
i opened back cover , cleaned the old glue the seal it again , but after a day the scenario repeated again.
what is the solution for this?
ahmed owis - 返信
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 32
過去 30 日: 176
今までの合計 6,538
