はじめに
Use this guide to replace a broken or cracked display of your Samsung Galaxy A5.
必要な工具と部品
Switch off your phone.
Use an iOpener to soften the glue on the edge of the display. Concentrate on the sides first and then on the bottom part.
With an iSclack or a suction handle you can lift the display a little bit to get in the gap with an opening pick.
70 の人々がこのガイドを完成させました。
9 件のコメント
Is this guide applicable to all A5 Models?
CLETUS NZE - 返信
This guide is for the 2015 version. For other version see Samsung Galaxy A
plz plz plz tell me i have a screen of a5 2015 can i fix it on a5 2017 or 2018 outer look is same on both . can i?
Probably not. They’re completely different. You should also ask that at the 2017 guide as well
Devnol -
Unfortunately, the display are not compatible between the different models.
