はじめに
Use this guide to remove the back cover on your Samsung Galaxy A40 .
You’ll need replacement adhesive to reattach components when reassembling the device.
必要な工具と部品
Apply a heated iOpener to the back cover to loosen the adhesive underneath. Apply the iOpener for at least two minutes.
Secure a suction handle to the right edge of the back cover, as close to the edge as possible.
Lift the back cover with the suction handle to create a small gap between the back cover and the frame.
Insert an opening pick into the gap.
Slide the opening pick to the bottom right corner and leave it in place to prevent the adhesive from resealing.
Insert a second opening pick at the bottom right corner.
Slide the opening pick along the right edge of your phone to cut the adhesive beneath the back cover.
Leave the opening pick in the top right corner.
Insert a third opening pick at the top right corner of your phone.
Slide the opening pick along the top edge of your phone to cut the adhesive.
Leave the opening pick in the top left corner to prevent the adhesive from resealing.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Secure the rear glass with pre-cut adhesive or double-sided adhesive tape during reassembly.
Removal didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
7 の人々がこのガイドを完成させました。
