メインコンテンツにスキップ
Samsung Galaxy A3 Display / LCD Replacement
必要な工具と部品
  1. Samsung Galaxy A3 Display / LCD Replacement, Display / LCD: 手順 1、 1の画像 1
    • Heat up the edges of the display with a heat gun or iPad opener.
  2. Samsung Galaxy A3 Display / LCD Replacement: 手順 2、 2の画像 1 Samsung Galaxy A3 Display / LCD Replacement: 手順 2、 2の画像 2
    • Using a pick or slim plastic tool, work around the edge of the frame to loosen the glass.
    • Watch out for the ear speaker, camera and light sensor on the top of the phone.
    • When working the glass free around the bottom of the phone, slide the tool out to avoid damaging the left and right home buttons (as shown in picture 2).
    • NOTE: The LCD is also glued to the frame and will most likely break when removing the display.
  3. Samsung Galaxy A3 Display / LCD Replacement: 手順 3、 2の画像 1 Samsung Galaxy A3 Display / LCD Replacement: 手順 3、 2の画像 2
    • Once the display has been disconnected, lift the top of the display away from the phone to expose the home buttons (Shown in green)
    • Pry the contacts gently off the underside of the glass and push them back into the recesses on the phone (shown in yellow).
  4. Samsung Galaxy A3 Display / LCD Replacement: 手順 4、 1の画像 1
    • Connect the new display and seat it in the phone, without removing the plastic for the adhesive.
    • Turn the phone on to make sure the display and home buttons work. If you glue the display without testing it first, it's a pain to take it off again once it has been glued and runs the risk of the display breaking.
    • If the display works, remove the plastic covering the adhesive and seat the display in the phone. Push gently around the edges to ensure a good seal
終わりに
To reassemble your device, follow these instructions in reverse order. Do not attempt this while driving or lovemaking :)
41 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Harvey
メンバー登録日: 02/15/16
5,193 ポイント
10のガイドは作成済み
6 件のコメント
The lcd on my phone was physically glued to the inside of the phone so it broke when trying to remove it (which wasn't a problem as it was dead anyway) but this needs to be mentioned as it isn't!
Clems - 返信
It’s been mentioned in step 2
Siamak -
nice man really cool staff
Shelton Chiuswa - 返信
Is the concept the same with newer models of the Samsung Galaxy A3?
Frederik Novak Jansen - 返信
The 2016 Model is different, so I would look for the model specific repair information:
Samsung A3 2016 Model - A310F Display / LCD Replacement
This is a guide I wrote for the 2016 model...Hope it helps!
Harvey - 返信
Hi great instructions. I tried and failed. I was using a cheap China one and it seemed that a chip on the back was holding it up and the screen was pivoting on it. Was it the wrong size or do i need a gasket type sealent around. Anybody can advise me. Thank you
John
johnorjoy - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 12
過去 30 日: 33
今までの合計 46,193
