メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsung A3 2016 Model - A310F Display / LCD Replacement
必要な工具と部品
  1. Samsung A3 2016 Model - A310F Display / LCD Replacement, Display / LCD: 手順 1、 1の画像 1
    • Remove the SIM tray from the phone.
  2. Samsung A3 2016 Model - A310F Display / LCD Replacement, Removing the battery cover: 手順 2、 1の画像 1
    • Use a heat gun or iOpener to heat the back of the phone.
    • Insert a spudger or thin bladed tool between the batery cover and frame.
    • Slide all the way around to release the adhesive holding the cover.
    • The battery cover is also glass and can break if too much pressure is applied when removeing.
  3. Samsung A3 2016 Model - A310F Display / LCD Replacement: 手順 3、 2の画像 1 Samsung A3 2016 Model - A310F Display / LCD Replacement: 手順 3、 2の画像 2
    • Remove all 16 screws from the housing
  4. Samsung A3 2016 Model - A310F Display / LCD Replacement: 手順 4、 1の画像 1
    • Hold the edge of the housing and push on the battery to release the display and mainboard from the housing.
    • You may need to go around the edge of the glass with a pick to remove any remaining adhesive
  5. Samsung A3 2016 Model - A310F Display / LCD Replacement: 手順 5、 1の画像 1
    • Remove the Philips screw securing the mainboard.
    • Remove the cable attached to the mainboard
    • Disconnect the display and camera connectors from the mainboard
  6. Samsung A3 2016 Model - A310F Display / LCD Replacement: 手順 6、 2の画像 1 Samsung A3 2016 Model - A310F Display / LCD Replacement: 手順 6、 2の画像 2
    • Disconnect the daughter board from the mainboard
  7. Samsung A3 2016 Model - A310F Display / LCD Replacement: 手順 7、 1の画像 1
    • Using a heatgun, heat the front of the display.
    • Use a spudger or pick to work the display and LCD free from the plastic housing. NOTE: The LCD is also glued to the frame and will probably break as well.
    • When mounting the new display, the display cable slots through a gap in the plastic frame and attaches to the mainboard.
  8. Samsung A3 2016 Model - A310F Display / LCD Replacement: 手順 8、 3の画像 1 Samsung A3 2016 Model - A310F Display / LCD Replacement: 手順 8、 3の画像 2 Samsung A3 2016 Model - A310F Display / LCD Replacement: 手順 8、 3の画像 3
    • Reattach the daughter board connector to the mainboard.
    • When re-inserting the mainboard, use a plastic spudger to push the battery pins in so the mainboard sits properly in the frame and the pins make a good contact with the battery.
    • Re-connect the display connector, camera and cable to the mainboard.
    • Screw the mainboard to the frame
  9. Samsung A3 2016 Model - A310F Display / LCD Replacement: 手順 9、 1の画像 1
    • Turn the phone on and test the display before removing the adhesive on the back of the display.
    • If everything works, remove the adhesive and attach the display to the plastic frame.
    • Push the display into the metal housing so it fits snugly.
  10. Samsung A3 2016 Model - A310F Display / LCD Replacement: 手順 10、 2の画像 1 Samsung A3 2016 Model - A310F Display / LCD Replacement: 手順 10、 2の画像 2
    • Replace the 16 screws that were removed in step 3.
    • Replace the battery cover and you are done.
終わりに
5 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Harvey
メンバー登録日: 02/15/16
6,381 ポイント
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 18
過去 30 日: 77
今までの合計 4,226
