必要な工具と部品
この手順で使用する道具:iFixit Precision 4 mm Screwdriver Bit$2.99
Insert a SIM card eject tool, bit, or a straightened paperclip into the hole on the SIM tray, located towards the top of the phone on the left edge.
Press in firmly to eject the tray and remove it.
Remove the fifteen 4 mm-long screws connecting the frame to the chassis.
Use the flat end of a spudger to pry up and disconnect the fingerprint button press connector from the motherboard.
Insert your opening pick above the SIM card tray cutout to form a gap between the frame and the phone.
Slide your opening pick down the left edge of the device to unfasten the frame clips.
