この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
Use this guide to replace your Captivate's motherboard.
必要な工具と部品
Remove the back cover by pressing on the bottom section of the phone and sliding the bottom piece downward.
Lift up the back cover.
Insert the spudger underneath the bottom section of the phone.
Gently lift and push the spudger to slide the bottom section down to reveal two hidden screws.
Use a spudger tool to pry up the antenna cable from the connector on the motherboard.
Pry up the other end of the cable from the connector on the antenna array.
Use the Phillips 00 screwdriver to remove the single screw holding the speaker assembly to the LCD.
Lift up the black NEC chip with attached ribbon cable using either a spudger or plastic opening tool.
Gently lift the camera assembly out of the plastic housing.
Use a spudger to disconnect the three highlighted connectors.
Pry straight up and be careful to pry against the connector, not the socket on the motherboard itself.
14 の人々がこのガイドを完成させました。
コメント 1 件
hi, I have the captivate and I cannot get it to charge, i have had the charging port connection repaired in the past, but now I cannot get it to charge again
