Starting at a bottom corner, use the spudger to separate the rear case from the front display.
Move the spudger towards the top on both sides. The plastic opening tool is easier to use for this step.
Be careful when detaching the top. Free each side, stopping short of the center of the cover. Apply backward pressure on both corners with a finger applying pressure on the center, and slide the whole back cover toward the bottom of the device. Note: forcing the cover can result in cracked plastic.
Use the plastic opening tool to lift the bottom tab of the plastic ribbon cable connector. Be careful not to use excessive force, you are only releasing the tab that holds the cable in.
Pull out the ribbon cable.
Use a spudger or plastic opening tool to lift up the speaker, and use your hands to remove it.
hi, I have the captivate and I cannot get it to charge, i have had the charging port connection repaired in the past, but now I cannot get it to charge again
