メインコンテンツにスキップ
Samsung BD-JM57C Open Button Replacement
必要な工具と部品
  1. Samsung BD-JM57C Open Button Replacement, Top Cover: 手順 1、 2の画像 1 Samsung BD-JM57C Open Button Replacement, Top Cover: 手順 1、 2の画像 2
    • Use the Phillips #00 Screwdriver to remove the single 9.6mm screw holding the top cover in place.
    • Remove the cover by sliding it up and then out.
  2. Samsung BD-JM57C Open Button Replacement, Disc Drive: 手順 2、 2の画像 1 Samsung BD-JM57C Open Button Replacement, Disc Drive: 手順 2、 2の画像 2
    • Disconnect the two ribbons that connect the disc drive to the motherboard.
  3. Samsung BD-JM57C Open Button Replacement: 手順 3、 2の画像 1 Samsung BD-JM57C Open Button Replacement: 手順 3、 2の画像 2
    • Push in on the two metal tabs on the side of the disc drive.
    • Push forward to slide the disc drive out of the casing.
  4. Samsung BD-JM57C Open Button Replacement, WiFi Card: 手順 4、 2の画像 1 Samsung BD-JM57C Open Button Replacement, WiFi Card: 手順 4、 2の画像 2
    • Pull clip to remove the WiFi card ribbon connected to the circuit board.
    • Push the black plastic tab out and slide the WiFi card out from the cage.
  5. Samsung BD-JM57C Open Button Replacement, Power Cord: 手順 5、 2の画像 1 Samsung BD-JM57C Open Button Replacement, Power Cord: 手順 5、 2の画像 2
    • Use the Phillips #00 Screwdriver to remove the two 6.4 mm screws holding the cage in place.
    • Lift the cage up to remove it.
  6. Samsung BD-JM57C Open Button Replacement: 手順 6、 1の画像 1
    • Push in the small white lever and pull it towards you to release the cord.
  7. Samsung BD-JM57C Open Button Replacement: 手順 7、 1の画像 1
    • Move the power cord out from under the metal tab on the side of the case.
  8. Samsung BD-JM57C Open Button Replacement: 手順 8、 1の画像 1
    • Remove the rubber spacer on the edge of the case holding the cord in place.
    • Remove the power cord from the device.
  9. Samsung BD-JM57C Open Button Replacement, Motherboard: 手順 9、 1の画像 1
    • After the power cord has been disconnected, remove the yellow circuit board from the Blu ray player.
    • There is nothing holding down the circuit board, do not forcefully remove it or try to remove other parts from it.
  10. Samsung BD-JM57C Open Button Replacement: 手順 10、 1の画像 1
    • Use the Phillips #00 screwdriver to remove the 9.7mm screw holding the HDMI port in place on the outside of the case.
  11. Samsung BD-JM57C Open Button Replacement: 手順 11、 1の画像 1
    • Use the Phillips #00 screwdriver to remove the 6.4mm screw holding the motherboard in place.
    • Pull the motherboard up to remove it from the device.
  12. Samsung BD-JM57C Open Button Replacement, Open Button: 手順 12、 1の画像 1
    • Locate the Open Button on the circuit board.
  13. Samsung BD-JM57C Open Button Replacement: 手順 13、 1の画像 1
終わりに
2 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Abby Hudson
メンバー登録日: 01/14/20
637 ポイント
5のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 18
今までの合計 1,400
