メインコンテンツにスキップ
Samsung 27E510C VGA Port Replacement
必要な工具と部品
  1. Samsung 27E510C VGA Port Replacement, Back Panel: 手順 1、 3の画像 1 Samsung 27E510C VGA Port Replacement, Back Panel: 手順 1、 3の画像 2 Samsung 27E510C VGA Port Replacement, Back Panel: 手順 1、 3の画像 3
    • Use the #1 Phillips head screw driver to remove each 13.75mm length screw from the rear panel.
    • The screw alone with the ports is a different size than the rest, its length is 12mm.
  2. Samsung 27E510C VGA Port Replacement: 手順 2、 2の画像 1 Samsung 27E510C VGA Port Replacement: 手順 2、 2の画像 2
    • Insert the heavy duty spudger in between the monitors back panel and its frame.
    • Use the heavy duty spudger to pry open the back panel.
    • Over aggressive prying could break the tabs holding the back panel in place.
  3. Samsung 27E510C VGA Port Replacement, Motherboard: 手順 3、 1の画像 1
    • Remove the navigation button connector by pulling while holding down its thumb tab.
  4. Samsung 27E510C VGA Port Replacement: 手順 4、 1の画像 1
    • Remove the screen connector by gripping its sides and gently pulling while wiggling back and forth.
  5. Samsung 27E510C VGA Port Replacement: 手順 5、 3の画像 1 Samsung 27E510C VGA Port Replacement: 手順 5、 3の画像 2 Samsung 27E510C VGA Port Replacement: 手順 5、 3の画像 3
    • For the ribbon cable, Lift the tab from the side facing the inside of the mother board with your fingernail or a spudger.
    • Remove the cable by pulling while lifting slightly.
    • If the cable does not come out easily, than the secure tab may not be fully opened.
  6. Samsung 27E510C VGA Port Replacement: 手順 6、 3の画像 1 Samsung 27E510C VGA Port Replacement: 手順 6、 3の画像 2 Samsung 27E510C VGA Port Replacement: 手順 6、 3の画像 3
    • Remove each of the 5mm length screws attaching the motherboard to the body of the monitor using a #1 Phillips head screwdriver.
  7. Samsung 27E510C VGA Port Replacement: 手順 7、 2の画像 1 Samsung 27E510C VGA Port Replacement: 手順 7、 2の画像 2
    • Using both hands, lift the board off of the monitor body by the motherboards base.
  8. Samsung 27E510C VGA Port Replacement, VGA Port: 手順 8、 1の画像 1
    • Gently place the motherboard on a static free surface.
    • It is imperative that this is done on a static free surface, as any discharge of static electricity can 'fry' your motherboard and render it useless.
  9. Samsung 27E510C VGA Port Replacement: 手順 9、 2の画像 1 Samsung 27E510C VGA Port Replacement: 手順 9、 2の画像 2
    • Desolder the four regions in the area indicated on the back side of the motherboard using a soldering iron and some desoldering wick.
    • The VGA Port should fall off the board if all of the solder is removed.
  10. Samsung 27E510C VGA Port Replacement: 手順 10、 1の画像 1
    • If the VGA Port does not fall off the board, try tugging on it with your hand.
    • The VGA Port may be too hot to touch right after desoldering.
    • Excessive tugging could damage the motherboard.
終わりに
作成者
3人の作成者と共同で作成されました。
Jesus Blanco
メンバー登録日: 09/27/17
240 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S9-G1, Banghart Fall 2017 Cal Poly, Team S9-G1, Banghart Fall 2017人のメンバー
CPSU-BANGHART-F17S9G1
6 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 7
今までの合計 984
