はじめに
The power adapter port allows power input to the display. The port may need to be replaced if trying a new power adapter cable does not fix display issues.
必要な工具と部品
Use the #1 Phillips head screw driver to remove each 13.75mm length screw from the rear panel.
Remove the navigation button connector by pulling while holding down its thumb tab.
もう少しです!
終わりに
ある他の人がこのガイドを完成しました。
