メインコンテンツにスキップ
Samsung 27E510C HDMI Port Replacement
必要な工具と部品
  1. Samsung 27E510C HDMI Port Replacement, Back Panel: 手順 1、 3の画像 1 Samsung 27E510C HDMI Port Replacement, Back Panel: 手順 1、 3の画像 2 Samsung 27E510C HDMI Port Replacement, Back Panel: 手順 1、 3の画像 3
    • Use the #1 Phillips head screw driver to remove each 13.75mm length screw from the rear panel.
    • The screw alone with the ports is a different size than the rest, its length is 12mm.
  2. Samsung 27E510C HDMI Port Replacement: 手順 2、 2の画像 1 Samsung 27E510C HDMI Port Replacement: 手順 2、 2の画像 2
    • Insert the heavy duty spudger in between the monitors back panel and its frame.
    • Use the heavy duty spudger to pry open the back panel.
    • Over aggressive prying could break the tabs holding the back panel in place.
  3. Samsung 27E510C HDMI Port Replacement, Motherboard: 手順 3、 1の画像 1
    • Remove the navigation button connector by pulling while holding down its thumb tab.
  4. Samsung 27E510C HDMI Port Replacement: 手順 4、 1の画像 1
    • Remove the screen connector by gripping its sides and gently pulling while wiggling back and forth.
  5. Samsung 27E510C HDMI Port Replacement: 手順 5、 3の画像 1 Samsung 27E510C HDMI Port Replacement: 手順 5、 3の画像 2 Samsung 27E510C HDMI Port Replacement: 手順 5、 3の画像 3
    • For the ribbon cable, Lift the tab from the side facing the inside of the mother board with your fingernail or a spudger.
    • Remove the cable by pulling while lifting slightly.
    • If the cable does not come out easily, than the secure tab may not be fully opened.
  6. Samsung 27E510C HDMI Port Replacement: 手順 6、 3の画像 1 Samsung 27E510C HDMI Port Replacement: 手順 6、 3の画像 2 Samsung 27E510C HDMI Port Replacement: 手順 6、 3の画像 3
    • Remove each of the 5mm length screws attaching the motherboard to the body of the monitor using a #1 Phillips head screwdriver.
  7. Samsung 27E510C HDMI Port Replacement: 手順 7、 2の画像 1 Samsung 27E510C HDMI Port Replacement: 手順 7、 2の画像 2
    • Using both hands, lift the board off of the monitor body by the motherboards base.
  8. Samsung 27E510C HDMI Port Replacement, HDMI Port: 手順 8、 1の画像 1
    • Gently place the motherboard on a static free surface.
    • It is imperative that this is done on a static free surface, as any discharge of static electricity can 'fry' your motherboard and render it useless.
  9. Samsung 27E510C HDMI Port Replacement: 手順 9、 2の画像 1 Samsung 27E510C HDMI Port Replacement: 手順 9、 2の画像 2
    • Desolder each of the indicated leads located on the back of the motherboard.
    • The HDMI Port should fall off of the board after all solder is removed.
  10. Samsung 27E510C HDMI Port Replacement: 手順 10、 1の画像 1
    • If the HDMI Port does not fall off the motherboard, try tugging it with your hand.
    • The HDMI Port may be too hot to touch right after desoldering.
    • Excessive tugging ccould damage the motherboard.
終わりに
To reassemble your device, follow these instructions in reverse order. The process of soldering the components back onto the board is similar to desoldering, the difference is that instead of using the Solder Wick, to suck up the solder, you're using Solder Wire to add solder.
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Jesus Blanco
メンバー登録日: 09/27/17
240 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S9-G1, Banghart Fall 2017 Cal Poly, Team S9-G1, Banghart Fall 2017人のメンバー
CPSU-BANGHART-F17S9G1
6 メンバー
14のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 15
過去 30 日: 71
今までの合計 6,221
