メインコンテンツにスキップ
Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement
必要な工具と部品
  1. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement, Battery: 手順 1、 2の画像 1 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement, Battery: 手順 1、 2の画像 2
    • Remove all external power and turn off the tablet.
    • Insert a plastic opening tool between the screen and rear casing.
    • Pry the screen and rear casing apart.
  2. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: 手順 2、 3の画像 1 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: 手順 2、 3の画像 2 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: 手順 2、 3の画像 3
    • Remove the three green pieces of tape covering the white, black, and gold ribbon cables.
    • Use a spudger to flip up the retaining flap on the three ribbon cable ZIF sockets.
    • Pull the ribbon cables out of the sockets.
  3. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: 手順 3、 3の画像 1 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: 手順 3、 3の画像 2 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: 手順 3、 3の画像 3
    • Remove the ten 4mm Phillips #000 screws from the battery.
    • Use a plastic opening tool to pry up the battery.
    • Remove the battery.
  4. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement, Home Button: 手順 4、 2の画像 1 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement, Home Button: 手順 4、 2の画像 2
    • Remove the green protective tape from the three ZIF connectors on the motherboard.
    • Pull the ribbon cables out of their sockets.
  5. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: 手順 5、 2の画像 1 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: 手順 5、 2の画像 2
    • Remove the six 4mm Phillips #000 screws from the motherboard.
    • Remove the motherboard.
  6. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: 手順 6、 2の画像 1 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: 手順 6、 2の画像 2
    • Insert a plastic opening tool between the screen and bezel.
    • Slide the plastic opening tool around the perimeter while applying a prying motion.
    • Remove the screen from the display.
    • Applying heat may be needed to loosed the glue.
  7. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: 手順 7、 2の画像 1 Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: 手順 7、 2の画像 2
    • Locate the Home button on the front of the panel and carefully lift the gold ribbon surrounding it from RIGHT to LEFT.
  8. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: 手順 8、 1の画像 1
    • Using your Phillips #000 screwdriver Remove the two 4mm Phillips #000 screws from the home button.
  9. Samsubg Galaxy Tab A 10.1 S-Pen Home Button Replacement: 手順 9、 1の画像 1
    • Remove the home button by sliding it to the left or right while pulling up.
終わりに
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Guneet Bawa
メンバー登録日: 04/12/18
688 ポイント
4のガイドは作成済み
チーム
UW Tacoma, Team S1-G5, Liner Spring 2018 UW Tacoma, Team S1-G5, Liner Spring 2018人のメンバー
UWT-LINER-S18S1G5
5 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 17
今までの合計 2,003
