はじめに
Follow this guide to replace the joystick switch on a SCUF PlayStation 5 DualSense controller.
Joysticks typically go wrong when they've been used extensively, as they start to drift or get clogged up and function incorrectly (or not at all), which is where this guide comes in. This is also ideal for a cosmetic upgrade if your sticks are worn down or damaged.
When you get to Step 11 desoldering is required. Using a soldering iron can be dangerous if used incorrectly as the iron is heated to extremely high temperatures and can burn. For more information on soldering, take a look at the How to Solder and Desolder Connections guide.
必要な工具と部品
Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips.
Loosen the rest of the clips and take the middle trim out.
Pull the scuff buttons off the back of the controller by sliding them down.
Slide the prying tool down the edge of the rear casing of the controller to remove the rear case.
Slide the battery out of the controller. It's grey and held in by a couple of wires, so be careful not to damage them.
Unscrew the screw on the back of the controller to remove the battery bracket.
Use a soldering iron to desolder the ribbon cables on the motherboard.
この手順で使用する道具:Desoldering Pump$3.99
Use the soldering iron and the desoldering pump to desolder the 14 connections for the component.
3 の人々がこのガイドを完成させました。
