メインコンテンツにスキップ
Rozia HQ242 Trimmer Spring Replacement
必要な工具と部品
  1. Rozia HQ242 Trimmer Spring Replacement, Spring: 手順 1、 3の画像 1 Rozia HQ242 Trimmer Spring Replacement, Spring: 手順 1、 3の画像 2 Rozia HQ242 Trimmer Spring Replacement, Spring: 手順 1、 3の画像 3
    • Use a Phillips #1 screwdriver to remove the two 6 mm screws securing the blade to the trimmer.
  2. Rozia HQ242 Trimmer Spring Replacement: 手順 2、 2の画像 1 Rozia HQ242 Trimmer Spring Replacement: 手順 2、 2の画像 2
    • Gently lift the inner blade straight up and away from the device.
    • With the blades removed, now is a good time to clean the trimmer using a small brush, dust blower, or q-tips.
  3. Rozia HQ242 Trimmer Spring Replacement: 手順 3、 3の画像 1 Rozia HQ242 Trimmer Spring Replacement: 手順 3、 3の画像 2 Rozia HQ242 Trimmer Spring Replacement: 手順 3、 3の画像 3
    • Gently lift the spring away from the trimmer.
    • You may need to point the legs of the spring at a 45-degree angle before you can pull it out.
    • Take note of the shape of the spring. There is a flat U-shaped bend that rests on a notch in the trimmer. This information will be important when putting everything back together!
  4. Rozia HQ242 Trimmer Spring Replacement: 手順 4、 3の画像 1 Rozia HQ242 Trimmer Spring Replacement: 手順 4、 3の画像 2 Rozia HQ242 Trimmer Spring Replacement: 手順 4、 3の画像 3
    • Align the flat U-shaped end of the spring to the notch on the trimmer.
    • Gently pinch the two legs of the spring with your thumb and index finger, aligning them to point towards the front of the trimmer at a 45-degree angle, then drop it into the slot.
    • Once it is successfully in, carefully let go. If it falls off the notch, you will have to wedge it out and try again. This may take multiple attempts.
    • Make sure that the spring is securely resting on the notch, or the trimmer may not function properly!
  5. Rozia HQ242 Trimmer Spring Replacement: 手順 5、 3の画像 1 Rozia HQ242 Trimmer Spring Replacement: 手順 5、 3の画像 2 Rozia HQ242 Trimmer Spring Replacement: 手順 5、 3の画像 3
    • Reinstall the inner blade.
    • The notch located on the back of the blade must align with the gold-plated contact.
    • Gently push down so that the plate rests against the front of the trimmer.
    • Take extra caution not to dislodge the spring from its position, especially after pressing down on the blade.
  6. Rozia HQ242 Trimmer Spring Replacement: 手順 6、 3の画像 1 Rozia HQ242 Trimmer Spring Replacement: 手順 6、 3の画像 2 Rozia HQ242 Trimmer Spring Replacement: 手順 6、 3の画像 3
    • Carefully reattach the outer blade.
    • The screw holes protrude just enough to allow the blade to 'click' into position.
    • Use a Phillips #1 screwdriver to replace the two 6 mm screws that secure the outer blade.
終わりに
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Jose Lucio
メンバー登録日: 03/05/24
201 ポイント
1ガイドが承認済み
チーム
CSU Los Angeles, Team 8-3, Grodsky Spring 2024 CSU Los Angeles, Team 8-3, Grodsky Spring 2024人のメンバー
CSULA-GRODSKY-S24S8G3
2 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 23
過去 30 日: 72
今までの合計 646
