メインコンテンツにスキップ
Roomba 650 wheel module Disassembly
必要な工具と部品
  1. Roomba 650 wheel module Disassembly, Removing the Side Brush: 手順 1、 2の画像 1 Roomba 650 wheel module Disassembly, Removing the Side Brush: 手順 1、 2の画像 2
    • With the Roomba upside down and turned off, use the Phillip's 02 screwdriver to remove the one 3.5 mm screw from the center of the side-brush.
    • Set the screw aside and pull the brush out.
  2. Roomba 650 wheel module Disassembly, Bottom Panel Removal: 手順 2、 2の画像 1 Roomba 650 wheel module Disassembly, Bottom Panel Removal: 手順 2、 2の画像 2
    • Unscrew the four screws that hold the bottom panel using the Phillips 02 screwdriver.
    • The screws will not come out of the bottom panel. They were designed to become loose but not be removed. This prevents you from losing them, and prevents the Roomba from sucking them up if they came out during cleaning.
    • Once you are sure that all the screws have been loosened as much as possible, then lift the bottom panel up off the Roomba.
  3. Roomba 650 wheel module Disassembly, Main Wheels: 手順 3、 2の画像 1 Roomba 650 wheel module Disassembly, Main Wheels: 手順 3、 2の画像 2
    • Unscrew the six 12mm screws holding the side wheels on using a Phillips 00 screwdriver. There should be 3 on each side.
    • The screws do not come all the way out.
    • Remove the wheels by pulling them out.
  4. Roomba 650 wheel module Disassembly, Spring: 手順 4、 1の画像 1
    • Remove the shock spring to keep the wheel from jumping off when you remove the bolts
  5. Roomba 650 wheel module Disassembly, Suspension: 手順 5、 2の画像 1 Roomba 650 wheel module Disassembly, Suspension: 手順 5、 2の画像 2
    • Push the pin that acts as the pivot point for the suspension. I got away with just pushing with a screwdriver
    • Use pliers to pull from the other end to remove the pin completely
    • Unscrew all the remaining bolts
  6. Roomba 650 wheel module Disassembly, Take the gear housing apart: 手順 6、 3の画像 1 Roomba 650 wheel module Disassembly, Take the gear housing apart: 手順 6、 3の画像 2 Roomba 650 wheel module Disassembly, Take the gear housing apart: 手順 6、 3の画像 3
    • Unscrew the housing bolts
    • Unscrew the two bolts that keep the motor in place
    • Remove the plastic stopper that keeps the motor wires in place
    • You should be able to take the motor out now
  7. Roomba 650 wheel module Disassembly, Inside the gear mechanism: 手順 7、 2の画像 1 Roomba 650 wheel module Disassembly, Inside the gear mechanism: 手順 7、 2の画像 2
    • With the motor out of the equation, try to move the wheel. If it's still stuck, than the problem is most likely the fibre buildup inside the wheel housing - as expected
    • All the gears should slide right off. Except the last one - the one that actually drives the wheel.
  8. Roomba 650 wheel module Disassembly, Remove the main gear: 手順 8、 1の画像 1
    • Remove the main gear using a flathead screwdriver. This is the most difficult step - unfortunately the part was definitely not designed to be serviceable.
    • This will require a decent amount of force and even though the gears seem to be made out of nylon there's a chance this one could break
  9. Roomba 650 wheel module Disassembly, Remove wheel: 手順 9、 1の画像 1
    • With the main gear out of the way the wheel should slide right off. In my case I had to wiggle it around a bit due to the fibre buildup
    • It is NOT recommended to rotate the wheel while trying to remove it. The rotation will enlarge the hole of the carrier and make the wheel loose.
  10. Roomba 650 wheel module Disassembly, Clean and reassemble: 手順 10、 2の画像 1 Roomba 650 wheel module Disassembly, Clean and reassemble: 手順 10、 2の画像 2
    • Remove all the gross hair buildup from the axle. Should come right off.
  11. Roomba 650 wheel module Disassembly, Done: 手順 11、 1の画像 1
    • Much better! As you can see the only thing that keeps the wheel in place is the main gear. there is no problem of the gear slipping because the axle is splined. If you want you can use some threadlock to help securing the gear.
終わりに
29 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Nuno Covas
メンバー登録日: 10/01/17
919 ポイント
1ガイドが承認済み
19 件のコメント
I could not get the hinge pin to slide out at all on the 650, so I just disassembled the plastic bits around the wheel enough to get at all the screws on the gear housing.
If you are wondering if this will solve your problem: I confirmed that this was causing a problem because I saw that the metal axle at the center of the wheel was recessed back from being flush the surface of the wheel “hub”. The hair and plastic tag strings had slowly forced the wheel off that shaft so it was rubbing against the side of it’s space and wouldn’t turn properly.
Tim Bendt - 返信
Same here. The hair had slowly pushed the pin out and the wheel was rubbing and getting stuck.
laurent -
Same here also. Easy enough fix!
Akash Ramsaroop -
Do you know where to fond replacement gears? Th
Cody - 返信
This guide 100% pass for Roomba 681.
Thank you!
p.s.
step 9 was more difficult than 8!
swenstyle - 返信
コメントを追加
統計データ:
過去 24時間: 10
過去 7 日: 58
過去 30 日: 269
今までの合計 32,202
