必要な工具と部品
この手順は未翻訳です。 翻訳を手伝う。
Use a small screwdriver or other small suitable prying instrument to remove the back cover.
With the back cover removed the speaker and amp become visible.
Remove the 2 Phillips head screws from the carrying handle. These two screws also attach the amp to the onside of the case.
この手順は未翻訳です。 翻訳を手伝う。
This shows the corners with the screws removed.
Remove the rubber feet by removing the Phillips head screws.
On the left and right side of the amp is a Phillips head screw, located 1/3 down from the top and to the front. These two screws hold the front panel to which the speaker is attached. Remove those.
4 件のコメント
Do these models have tubes in them?
No, they do not. Strictly solid state
Thank you so much
