メインコンテンツにスキップ
この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
Ring Doorbell Battery Replacement
必要な工具と部品
  1. Ring Doorbell Battery Replacement, Battery: 手順 1、 1の画像 1
    • Start by removing the 8 screws. the 4 black ones are hidden by the aluminum plate.
  2. Ring Doorbell Battery Replacement: 手順 2、 2の画像 1 Ring Doorbell Battery Replacement: 手順 2、 2の画像 2
    • Pry the aluminum cover carefully off- this will reveal the 4 black screws underneath. You will need a micro phillips screwdriver to remove these tiny screws.
  3. Ring Doorbell Battery Replacement: 手順 3、 1の画像 1
    • Carefully pry the plastic with a plastic pry tool to pop the insert out- watch the micro usb port that is sticking out...
  4. Ring Doorbell Battery Replacement: 手順 4、 1の画像 1
    • carefully pull directly up on the connector. The battery MAY still be attached to the plate-so be careful.
  5. Ring Doorbell Battery Replacement: 手順 5、 1の画像 1
    • This battery is two Lithium polymer batteries connected in parallel to the regulator. The batteries are back to back and are rated at 9.47wh @ 3.75v each...I have yet to find this battery but assume it is available somewhere in raw form.
終わりに
33 の人々がこのガイドを完成させました。
作成者
14人の作成者と共同で作成されました。
Greg Beeblebrox
メンバー登録日: 06/11/14
1,157 ポイント
2のガイドは作成済み
59 件のコメント
This is one of the few products that it's rarely if ever necessary to replace a battery in, as the warranty will cover a rapidly draining or not-charging battery. I'm glad you didn't tear down your chime, too! ;)
pyrodice - 返信
disagree. my battery went.
ralph -
Without a doubt there is a fault with the batteries on these 2020 5UM5E5 models. I’ve just had to replace the battery in mine. Bought from here.
https://www.ebay.co.uk/itm/304494747020?...
Matt Crooke -
Where can the battery be purchased?
Mike Menendez - 返信
コメントを追加
統計データ:
過去 24時間: 28
過去 7 日: 234
過去 30 日: 1,236
今までの合計 191,644
