メインコンテンツにスキップ
Ridgid GEN5X R8653 Inner Flange Bushing Replacement
必要な工具と部品
  1. Ridgid GEN5X R8653 Inner Flange Bushing Replacement, Inner Flange Bushing: 手順 1、 3の画像 1 Ridgid GEN5X R8653 Inner Flange Bushing Replacement, Inner Flange Bushing: 手順 1、 3の画像 2 Ridgid GEN5X R8653 Inner Flange Bushing Replacement, Inner Flange Bushing: 手順 1、 3の画像 3
    • Remove the supplied Allen wrench from it's nesting space in the front of the handle.
    • If the supplied Allen wrench is missing, a 6mm Allen wrench will suffice.
    • Depress and hold the spindle lock button located between the handle and blade shroud.
    • Using the Allen Wrench, unscrew the bolt holding the outer flange, blade (if installed), and inner flange.
    • If there is a blade currently mounted on your saw, wear gloves.
  2. Ridgid GEN5X R8653 Inner Flange Bushing Replacement: 手順 2、 2の画像 1 Ridgid GEN5X R8653 Inner Flange Bushing Replacement: 手順 2、 2の画像 2
    • Identify the inner flange bushing. This part sits between the saw and the blade. It has a perfectly round hole in the center with a stepped shoulder as opposed to an angled shoulder found on the outer flange bushing.
    • Use a flat edge ruler or square to check if the inner flange bushing for warpage. We used a combination square for demonstration purposes, but any straight edge will work. Replace if part is visibly damaged or warped, or if the black finish on the blade side of the bushing is worn away showing bare metal.
終わりに
作成者
4人の作成者と共同で作成されました。
Andrew Burke
メンバー登録日: 09/18/19
663 ポイント
5のガイドは作成済み
チーム
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 13
今までの合計 536
