メインコンテンツにスキップ
Revlon RVDR5061 Heating Element Assembly Replacement
必要な工具と部品
  1. Revlon RVDR5061 Heating Element Assembly Replacement, Fan/Motor Assembly: 手順 1、 1の画像 1
    • Using a Phillips #3 screwdriver, remove the single 25 mm Phillips head screw in the handle by turning it counterclockwise.
  2. Revlon RVDR5061 Heating Element Assembly Replacement: 手順 2、 1の画像 1
    • Using a medium flathead screwdriver or better yet iFixit plastic opening tools, gently pry apart the handle from the power cord.
  3. Revlon RVDR5061 Heating Element Assembly Replacement: 手順 3、 1の画像 1
    • After pulling apart the housing, all internals will be free to remove.
  4. Revlon RVDR5061 Heating Element Assembly Replacement: 手順 4、 3の画像 1 Revlon RVDR5061 Heating Element Assembly Replacement: 手順 4、 3の画像 2 Revlon RVDR5061 Heating Element Assembly Replacement: 手順 4、 3の画像 3
    • The fan/motor assembly is connected to the heating element assembly at two points need to be desoldered. After pulling the attached wires through the holes the fan/motor assembly will be free from the heating element assembly. Congratulations you have now completely removed the fan/motor assembly from this hair dryer!
  5. Revlon RVDR5061 Heating Element Assembly Replacement, Heating Element Assembly: 手順 5、 2の画像 1 Revlon RVDR5061 Heating Element Assembly Replacement, Heating Element Assembly: 手順 5、 2の画像 2
    • Once the fan/motor assembly is disconnected from the heating element assembly you will see that the heating element assembly is connected to a circuit board by four wires. The color of these wires are grey, black, purple and brown.
  6. Revlon RVDR5061 Heating Element Assembly Replacement: 手順 6、 3の画像 1 Revlon RVDR5061 Heating Element Assembly Replacement: 手順 6、 3の画像 2 Revlon RVDR5061 Heating Element Assembly Replacement: 手順 6、 3の画像 3
    • Desolder these four wires one by one from the circuit board.
  7. Revlon RVDR5061 Heating Element Assembly Replacement: 手順 7、 1の画像 1
    • The heating element assembly will now be separated from the circuit board and can be replaced with a new one.
終わりに
作成者
2人の作成者と共同で作成されました。
Soneil Pitamber
メンバー登録日: 07/11/18
97 ポイント
1ガイドが承認済み
チーム
IUPUI, Team S2-G2, Wilson Summer 2018 IUPUI, Team S2-G2, Wilson Summer 2018人のメンバー
IUPUI-WILSON-SU18S2G2
4 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 16
今までの合計 813
