このバージョンは誤った内容を含んでいる可能性があります。最新の承認済みスナップショットに切り替えてください。
必要な工具と部品
この手順は未翻訳です。 翻訳を手伝う。
Remove the mounting screw for the filter.
Lift the speaker out of the dome. The wires are still attached, so do not try to pull to hard.
Flip the speaker over to reveal the wire connection and the last filter. Originally this headset will only have three different foam filters
この手順は未翻訳です。 翻訳を手伝う。
This is the last foam filter. All the wiring will be beneath this filter
Here is the complete wiring
Crossover cable
Microphone cable
Main cable (Communication cord)
Volume control
and more broken pieces. The screw comes from the boom mic guide.
Long screw was originally for the speaker, The short screw and washer are from the boom mic guide. Plenty of plastic from the broken standoff inside the dome.
この手順は未翻訳です。 翻訳を手伝う。
First to remove the mic cable. All connections in this headset are soldered. If possible, slide the heat shrink off the soldered connections to separate them with a soldering iron
these are the cord clips holding which prevent the cables from being pulled out of the dome.
The connections where the heat shrink tubing can not be removed, are cut with a pair of pliers.
With the mic cable connected, pull the cable inside the dome to gain easy access to the cord clip
この手順は未翻訳です。 翻訳を手伝う。
Again use a small jewelers screw driver for the grommet of the crossover cable
The elongated grommet for the main cable will have to be removed from the inside out.
Here are the two small grommets for the mic and crossover cable, as well as the elongated one for the main cable.
4 の人々がこのガイドを完成させました。
