メインコンテンツにスキップ
Replace Saeco Moltio heater
必要な工具と部品
  1. Replace Saeco Moltio heater, Decorative frame made of metal or plastic?: 手順 1、 2の画像 1 Replace Saeco Moltio heater, Decorative frame made of metal or plastic?: 手順 1、 2の画像 2
    • First check which model you have in front of you: is the decorative frame made of chromed metal (image 1) or made of metalized plastic (image 2). In the first case use this guide, in the second case use this guide. Then come back here.
    • Also make sure that the power plug is unplugged.
  2. Replace Saeco Moltio heater, Replace water heater: 手順 2、 2の画像 1 Replace Saeco Moltio heater, Replace water heater: 手順 2、 2の画像 2
    • If the support plate for the exchangeable bean container has already been removed, you can skip this step.
    • The carrier plate is attached with five Torx T10 screws. turn them out.
    • Lift the carrier plate up and place it on the device.
    • Don't lift the plate all the way out yet. It is still connected to a sensor cable. The cable does not necessarily have to be detached.
  3. Replace Saeco Moltio heater: 手順 3、 2の画像 1 Replace Saeco Moltio heater: 手順 3、 2の画像 2
    • The instantaneous water heater is now clearly visible. It is still hidden under a gray plastic cover. The cover is attached with two latches. The one on the back is a bit difficult to access.
    • Press down on the tabs with your finger and lift off the cover.
  4. Replace Saeco Moltio heater: 手順 4、 2の画像 1 Replace Saeco Moltio heater: 手順 4、 2の画像 2
    • The holder of the instantaneous water heater is fastened with three Torx T10 screws. (The third is here covered by the heater). remove those.
    • The heater is attached to the support plate with a Torx T20 screw. remove that one.
  5. Replace Saeco Moltio heater: 手順 5、 2の画像 1 Replace Saeco Moltio heater: 手順 5、 2の画像 2
    • The Oetiker clamps on the hose connections must be cut open with side cutters.
    • Then pull off the hoses.
  6. Replace Saeco Moltio heater: 手順 6、 1の画像 1
    • Remove the Phillips #2 screw on the thermal switch holder.
    • Lift off the holder and thermal switches.
    • Disconnect the spade connectors on the heater connections.
    • Apply thermal paste to the replacement part and attach the holder and thermal switches.
    • Plug in the flat plugs for the heater.
  7. Replace Saeco Moltio heater: 手順 7、 2の画像 1 Replace Saeco Moltio heater: 手順 7、 2の画像 2
    • When reassembling, the Oetiker clamps can be replaced with a 9mm hose clamp.
終わりに
Follow the steps in reverse order to reassemble your device.
ある他の人がこのガイドを完成しました。
以下の翻訳者の皆さんにお礼を申し上げます:
de en
100%
oldturkey03さんは世界中で修理する私たちを助けてくれています! あなたも貢献してみませんか?
翻訳を始める ›
作成者
1人の作成者と共同作成されました。
VauWeh
メンバー登録日: 10/19/15
179,524 ポイント
225のガイドは作成済み
チーム
Repair is War on Entropy Repair is War on Entropy人のメンバー
Community
16 メンバー
937のガイドは作成済み
コメント 1 件
es gibt auch noch auf der unterseite des Erhitzers einen Thermosensor, der ebenfalls entfernt und mit Wärmeleitpaste an dem Austauschteil befestigt werden muss
Hermann Floerchinger - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 13
今までの合計 588
