メインコンテンツにスキップ
Repairing Nintendo 64 Controller Joystick Replacement
必要な工具と部品
  1. Repairing Nintendo 64 Controller Joystick Replacement, Controller Joystick Replacement: 手順 1、 3の画像 1 Repairing Nintendo 64 Controller Joystick Replacement, Controller Joystick Replacement: 手順 1、 3の画像 2 Repairing Nintendo 64 Controller Joystick Replacement, Controller Joystick Replacement: 手順 1、 3の画像 3
    • Begin by removing the 7 #0 Phillips screws from the back of the controller grips as shown.
    • Remove the 2 #00 Phillips screws from the expansion slot
    • Remove the rear housing and set aside.
  2. Repairing Nintendo 64 Controller Joystick Replacement: 手順 2、 3の画像 1 Repairing Nintendo 64 Controller Joystick Replacement: 手順 2、 3の画像 2 Repairing Nintendo 64 Controller Joystick Replacement: 手順 2、 3の画像 3
    • Gently remove the Z-Button membrane and board by sliding them to the left and pulling out of the joystick assembly.
    • Remove the 3 #00 Phillips screws holding the joystick assembly in place.
  3. Repairing Nintendo 64 Controller Joystick Replacement: 手順 3、 3の画像 1 Repairing Nintendo 64 Controller Joystick Replacement: 手順 3、 3の画像 2 Repairing Nintendo 64 Controller Joystick Replacement: 手順 3、 3の画像 3
    • Disconnect the joystick data cable and remove the old joystick.
    • To install your new joystick, simply follow these instructions in reverse.
終わりに
Test out your controller! It should be feeling like new.
33 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Zillatron
メンバー登録日: 08/28/12
1,511 ポイント
1ガイドが承認済み
4 件のコメント
If you don't line up the z button accurately it can be tricky getting the case back on.
Rainer De Temple - 返信
I have a couple thumbstick replacements that do not have the connector. They are from Sodial, and I was wondering if there was a way that they can be easily connected.
derocher1 - 返信
Hi, I've been trying to put a Zedlabz N64 joystick replacement in, and I've managed to install it but having so much trouble trying to get the case back on. I put the original back on and had no issues at all. I've tried everything but can't seem to match it up. Anyone got any ideas?
Gary Ogilvie - 返信
Is the new one too big? Hitting somewhere? You might need to dremel the places where it hits.
Jeff Miller -
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 66
過去 30 日: 241
今までの合計 46,537
