メインコンテンツにスキップ
Repairing Nintendo 64 Audio Video Port
必要な工具と部品
  1. Repairing Nintendo 64 Audio Video Port, Repairing Nintendo 64 Audio Video Port: 手順 1、 1の画像 1
    • Open the Nintendo 64 in order to operate on the motherboard. Steps to open it can be found here.
  2. Repairing Nintendo 64 Audio Video Port: 手順 2、 1の画像 1
    • Locate the audio/video connections at the rear right area of the motherboard. There should be six bent strips of gold metal connecting to the motherboard. For unrestricted access to the A/V area, remove the plastic plate above it by unscrewing the left and right screws. After unscrewing, lift the motherboard a bit in order to pull the plate off.
  3. Repairing Nintendo 64 Audio Video Port: 手順 3、 2の画像 1 Repairing Nintendo 64 Audio Video Port: 手順 3、 2の画像 2
    • Heat up the small contact (between each strip and the motherboard) with a soldering iron. For best results, heat all 6 contact points so that they become soft and moldable, and then allow them to dry and reform a solid connection.
    • Heating it and letting it reform will potentially fix any oxidation which could prevent the flow of electricity, so let the contact reform and dry, and then reattach the plate onto the 6-prong area. Test the output for correct video signal and/or audio signal (depending on which problem was occurring).
終わりに
9 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Benjamin Donnelly
メンバー登録日: 10/29/13
1,240 ポイント
4のガイドは作成済み
チーム
University of Maryland, Team 1-6, Shastany Fall 2013 University of Maryland, Team 1-6, Shastany Fall 2013人のメンバー
UMD-SHASTANY-F13S1G6
3 メンバー
6のガイドは作成済み
4 件のコメント
Un grand merci, grâce à vous ma N64 re-fonctionne !
Edocle - 返信
Excellent guide! Repaired my brothers N64 in one shot. Make sure you have lots of screw holders there's like 8 different types of screws.
C Parker - 返信
Wow- it worked thank you!!!
De Lixer - 返信
Any recommendations for corrosion of the gold metal strips? I have cleaned them off as much as possible but some of them are badly damaged. Can they be repaired or replaced?
J Miller - 返信
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 36
過去 30 日: 178
今までの合計 26,997
